-   -   miller furnace oil pump problem (http://www.diychatroom.com/f17/miller-furnace-oil-pump-problem-93417/)
brad j 01-25-2011 12:23 AM
I have a verry old mobile home miller furnace no matter how long I leave the bleader valve open I keep getting air
beenthere 01-25-2011 03:31 AM
Then you have a air leak in your oil line somewhere. Or, your out of oil.
brad j 01-25-2011 07:42 AM
thanks for the info I also noticed that i can get fuel to come out of the bleeder valve but no fuel to come out of the out line to the nozzle not a drip is the pump no good? I also have plenty of fuel thanks
Bondo 01-25-2011 08:57 AM
Ayuh,... How full of Crud is the oil Filter,..??
brad j 01-25-2011 11:26 AM
It had a lot of crud but I cleaned it and took the pump apart and cleaned it also
brad j 01-25-2011 11:30 AM
even Though i cleaned it thoroughly, it almost seems to act like a clogged carburator.
Bondo 01-25-2011 11:36 AM
Ayuh,... Then I'd Replace the pump, 'n the fuel Filter element...
brad j 01-25-2011 11:38 AM
Thanks for the advice. I appreciate it!
overcomer888 11-28-2012 04:39 PM
How to get air out of the system
hey BradJ did you ever figure out your problem will your Miller Furnace? MagicPatrick1 on youtube has the Anatomy of Oil Burner Service. If you have a filter it could be the oil filter you need to remove the nut at the top of it to drop it down and get the air out of there but according to the video do NOT touch the bleader on that if there is sludge in that unit clean it out and replace oil filter then close back up and then try to blead through blead tube. I'm telling you what the video states I am not a expert but alot of information he has given has been right on. If you own a beckette burner AF I can give you more inform if needed Let me know. I wish you the best.
