Miller Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 01-12-2011, 04:03 PM   #1
miller furnace
hi,i have a miller furnace,but when i took door off,everything on inside door,says its a nordyne,anyway,my model number is G5RKO6OC-12-H,and the serial number is G5R9607-00709and the flash code it giving is4 flashes,which says its ignition failure,what does that mean?live in Alberta,canada,and outside temperature is -26C,need help fast,thanks
scar is offline   Reply With Quote
Old 01-12-2011, 04:24 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 660
Ayuh,... Oil, or Gas,..??
Old 01-12-2011, 04:41 PM   #3
Rewards Points: 492
recent related post:
York Diamond 80 won't ignite
diyorpay is offline   Reply With Quote
The Following User Says Thank You to diyorpay For This Useful Post:
scar (01-12-2011)
Old 01-12-2011, 06:42 PM   #4
HVAC / Plumbing
Nordyne makes miller among others. Does ignitor glow ?
kenmac is offline   Reply With Quote
Old 01-12-2011, 07:30 PM   #5
natural gas
Old 01-12-2011, 07:33 PM   #6
yes,it glows,if i turn the thermostat to a lower setting,it won't start without lowering the thermostat below set temp and then set it to a higher setting,when thats done it starts,and keeps running ok sometimes ,but not other times??
Old 01-12-2011, 07:35 PM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 1,454
Is it in a mobile or prefab home? Post a pic of it with the doors off. I have worked on some of them and they are tricky and finicky with some problems only a experienced tech on them will know about.
Old 01-12-2011, 07:42 PM   #8
its in a prefab house,i'll try and send a pic.thanks
Old 01-12-2011, 08:04 PM   #9
miller furnace
[quote=scar;568736]yes,it glows,if i turn the thermostat to a lower setting,it won't start without lowering the thermostat below set temp and then set it to a higher setting,when thats done it starts,and keeps running ok sometimes ,but not other times??when the temp is lowered,below setting,when temp drops to new lower setting,instead of starting ,it gives a flash code of 4 ,which says its ignition failure?
Old 01-12-2011, 08:24 PM   #10
HVAC / Plumbing
Jump out the R & W wires & see if the unit stays on. If it's the original T.stat..Most times ,They use cheap T.stats in pre fabs like in the MH'S.
The Following User Says Thank You to kenmac For This Useful Post:
scar (01-12-2011)
Old 01-12-2011, 08:28 PM   #11
miller gas furnace
here a open door pic.
Old 01-12-2011, 09:40 PM   #12
Hvac Pro
yuri's Avatar
Not the nasty mobile home type I see with a plastic ventor fan so this one should be solvable. Not sure if it has a code for poor/low flame signal. Try clean the flame sensor with fine emory paper. Sits in front of one of the burners and looks like one of these. Make sure your gas meter AND its regulator outside are not covered in snow or ice. The vent on the regulator MUST NOT be blocked.
Old 01-12-2011, 09:55 PM   #13
ok,thanks,will try that and check gas meter.see what happens,it dosn't have a code for those,just a code that says it is ignition failure,and thats all.
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Miller G5RA furnace flame sensor problem mpit52 HVAC 3 01-16-2009 11:30 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Miller Furnace Problems Ajournyman HVAC 8 01-16-2008 09:33 AM
