Mice In Furnace Through Outside Air Inlet - HVAC - DIY Chatroom Home Improvement Forum
Old 06-17-2011, 01:03 PM   #1
mice in furnace through outside air inlet
How do you keep mice from entering the furnace combustion area, where they die and corrupt the air space around the furnace
With a 90% plus gas furnace, mice enter through the outside air inlet. This inlet is integrated with the combustion air exhaust. Exhaust out the center and fresh air in around the perimeter.
I can't be the only one dealing with this problem!
jsavage1502 is offline   Reply With Quote
Old 06-17-2011, 02:02 PM   #2
Retired from the grind
gregzoll's Avatar
Rewards Points: 6,638
If they are entering, that means that it is either too close to the ground, does not extend out far enough, or has something that allows them to jump onto the pipe in order to get in. I do not have anything on mine to stop mice or other critters, and have not had any problems with them entering my system.
Tags
mice , rodents
How to Get Rid of Mice biz123 Pest Control 8 08-06-2012 07:01 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
dead mice in furnace TerPer HVAC 8 01-16-2011 07:26 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
