Metal Or FlexFoil Duct - HVAC - DIY Chatroom Home Improvement Forum
Old 02-28-2011, 07:39 PM   #1
Question
Metal or FlexFoil Duct
I did search and read on this forum that Metal duct is better than flex foil, but I am confused why my local professionals(through servicemagic) are recommending flexfoil instead of metal ducts.
We recently bought a house built in 1983 and the duct work in attic seems to be falling apart, I had to tie the insulation which was falling apart with twine. I need to fix my ducts before summer and to do that I contacted 3 professionals in DFW area and all of them recommended and quoted for flexfoil when I asked about metal duct they seemed to resist the idea.
Can anybody here shed some light on why metal duct is not being recommended in DFW area? or is it just that I am contacting wrong people. I am new to this forum, can I post in this forum so that professionals on here can give me quote for new ductwork?.
I have a baby coming in next few weeks so I need to fix my duct/attic before summer any help is appreciated.
Thanks.
rchuk is offline   Reply With Quote
Old 02-28-2011, 07:45 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 82
It's easier for them to install the flex duct. I would say use the metal. A cat got into my basement and shredded my flex duct.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 02-28-2011, 07:45 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
if its in your attic, it should be insulated flex duct work, not flexfoil. If it were run in rigid duct work then it would have to be insulated as well, but would cost you a lot more!
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 02-28-2011, 08:14 PM   #4
Some of them did say the insulation would be R8 around the flex duct.
Is it ok to ask professionals of this forum in DFW area to contact me?. I read the forum rules but they didn't mention anything about homeowners asking for professional work done.
Thanks.
Old 02-28-2011, 08:18 PM   #5
Metal duct is better because the ribbed inside of Flex duct which has a higher friction rate and increses static pressure. Generally, the duct airflow charts will call for 1 size bigger in flex, and yes it should be good flex duct. Rigid duct is very laborious, sections are each 3-5' each has to be fitted together, airsealed,etc. Then it must be wrapped in a good R rated wrap. A lot of long, hot dirty work...get a quote both ways.
Poppyloppy is offline   Reply With Quote
Old 02-28-2011, 09:02 PM   #6
This is how my attic insulation looks. by the way can somebody guess what those plastic exhaust to outside are in the second picture?.
Thanks.
Old 02-28-2011, 09:19 PM   #7
Looks like 2 plumbing vent stacks and a metal drier vent. Insulated flex is what you have now so if it's replaced with the same size then the air flow will be the same. Insulated metal duct is better IMO but most people do not want to pay the price difference between it and stringing insulated flex. Wrapped pipe could easily be double the cost.
Old 02-28-2011, 09:41 PM   #8
HVAC / Plumbing
Bad for the home owner. Builders only pay for the cheapest jobs.Not quality jobs. You need all that re- done. Someone will install everything the correct way. You will just have to pay $$ to get it done the correct way
kenmac is offline   Reply With Quote
Old 02-28-2011, 10:10 PM   #9
The home is about 28 years old, I guess duct work has seen better days, I just hope new duct work, insulation upgrades will have good return of investment. right now energy bill is ridiculous, I am afraid because of his bad duct work and insulation the a/c unit will give in soon and I will end up paying for a new one.
Old 03-01-2011, 12:10 AM   #10
HVAC Supermodel
unicursalhex's Avatar
Rewards Points: 150
Damn, those little "distribution boxes" are horrible. Typically I give a quote for rigid and flexible ducting as I want my customers to have the option for an optimal duct system (rigid pipe). 19 out of 20 times they choose flexible duct because its usually costs about half the price of rigid ducting. The fact that the contractors you talked to would not give you a quote for rigid when you asked would make me steer clear of them.
unicursalhex is offline   Reply With Quote
Tags
duct , flex , flexfoil , foil , metal
?an Insulated Flexible Duct - half attached and half unattached ? tran Roofing/Siding 2 06-21-2012 06:25 PM
Metal duct or flex? smokey982 HVAC 6 08-06-2010 06:20 AM
Transistion from Duct Board to Sheet metal zootjeff HVAC 0 06-29-2009 12:05 PM
Return duct "boot or no boot" ads67 HVAC 16 01-10-2009 09:38 AM
Tapping into existing metal duct Mike_Atlanta HVAC 1 11-30-2007 12:07 AM
