Metal Building Heat - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-19-2008, 10:41 AM   #16
Originally Posted by buzzurd View Post
Yes...15 foot ceiling at the peak.It is fiberglass insulation wrapped in plastic.Not sure of the R value, probably not that high.No windows.No exhaust system.I'm not out there but a few hours during the week but pretty much all day on weekends.I would like to keep the building around 50 degrees at all times to keep things from sweating.The slab is not insulated.
Now for my stupid question as I'm not that familiar with hvac.
What is radiant heat?
Thanks again,
Buzzurd
The nice thing about radiant heat is that it heats up things rather than air (which in turn heats up the air).
If you had a car in there it would heat up the car and the car would radiate the heat out.
It doesn't make a lot of noise compared to a big shop heater.
The down side is that it is slower to heat than a conventional heater.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 10-19-2008, 10:47 AM   #17
Yeah but once up to temp you can open those doors and most of your heat remains. Especially the slab. It would act like a heat sink and mak that place nice and toasty.
hvaclover is offline   Reply With Quote
Old 10-19-2008, 10:59 AM   #18
And once that slab gets warm it will continue to heat for a long time.
Old 10-19-2008, 11:28 AM   #19
WORD!
Old 10-19-2008, 12:24 PM   #20
OK....I'm convienced!!!!!!Now how about a reccomendation as to which heater will do the trick,or will I need more then one?
Buzzurd
buzzurd is offline   Reply With Quote
Old 10-19-2008, 12:50 PM   #21
Buzzurd
Google radiant heatsupplies. Then look for somebody by you.
They can size it and sell you what you need.
Proper way to install chimney pipe in metal building roof jonblack Building & Construction 15 01-31-2012 10:50 AM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
Help with metal building add-on wooddocinc Building & Construction 3 01-31-2008 01:20 PM
grounding pole building sheet metal? borderbuster Electrical 2 07-08-2007 02:11 AM
kit metal building as addition structure weaver Building & Construction 9 08-08-2006 09:59 AM
