Merv Filter Rating? - HVAC - DIY Chatroom Home Improvement Forum
Old 03-28-2013, 08:55 AM   #1
Rewards Points: 77
Merv filter rating?
Hello Guru's.
New Split system Central Air system last year. Trane Hyperion XL 2.5 ton with Variable speed motor. What MERV rating filter should I use or can I use with this system without restricting air flow? Should I just stick with 6 or 8?
Thanks,
~S
Skelleyman is offline   Reply With Quote
Old 03-28-2013, 10:03 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,422
as long as you or the installer does a temp rise check of the furnace and checks the freon level of the AC and pressures to make sure you are getting enough airflow you should easily be able to use a Merv 10 filter as that blower has tons of airflow and can handle up to a Merv 16 filter. The speed of it needs to be set with a higher Merv filter and should be properly done at install and with normal yearly maintenance. Merv 8 should be safe now but the airflow should be checked to make the equipment last longer and for efficiency etc.
The Following User Says Thank You to yuri For This Useful Post:
ben's plumbing (03-28-2013)
Which MERV Filter To Go With? Soco80p HVAC 1 05-20-2012 07:18 PM
Inline water filter for built-in fridge (water supply line on top) Druidia Appliances 5 03-10-2012 01:05 AM
Inground pool and filter...HELP! Blpavlovich Building & Construction 2 06-09-2011 06:49 PM
furnace filter fit?? Doug7852 HVAC 4 04-01-2011 11:45 AM
installing whole house filter on outside of house MikeInFL Plumbing 3 06-12-2010 05:47 PM
