Old 08-05-2009, 12:55 PM   #1
Measuring TESP
Hi everyone. I was wondering how you go about measuring TESP if the evap coil is right on top of the AH. I know you measure directly after the filter (blower compartment) and between the AH and evap coil, but in several cases, it is difficult to find a good place to measure between AH and evap coil..
Any tips you have would be helpful.
Thanks.
pirateo is offline   Reply With Quote
Old 08-05-2009, 04:14 PM   #2
An old Tradesmen
Measuring TESP
Drill hole in the furnace jacket.
Or, remove limit, and measure there.
Old 08-06-2009, 11:16 AM   #3
Measuring TESP
Thanks beenthere.
Do you typically also drill a hole in the blower compartment door for the negative pressure, or do you remove a side plug and test there?
Old 08-06-2009, 12:02 PM   #4
An old Tradesmen
Measuring TESP
Side plug if there is one. Or through a rubber wiring harness.
Drill if not.
Old 08-06-2009, 12:13 PM   #5
Measuring TESP
Drill if not.
Thanks for your help.
Old 08-10-2009, 06:37 PM   #6
Measuring TESP
Just wondering, when I remove the limit and use that hole to test, can I just let the limit hang down or should I remove the two wires from it first before I turn the power back on?
Don't want to shock myself.
Old 08-10-2009, 07:13 PM   #7
An old Tradesmen
Measuring TESP
It can hang, as long as you keep it from shorting against anything.
Old 08-11-2009, 12:43 PM   #8
Measuring TESP
Thanks for all of your help.
measuring A/C BTU/hr output Yoyizit HVAC 0 07-24-2009 02:52 PM
laser measuring tools kerstin Carpentry 3 05-31-2009 09:44 PM
laser measuring tools kerstin Tools 1 05-26-2009 02:57 AM
measuring inside corners for crown molding peciousroy Carpentry 13 08-04-2008 06:39 AM
Measuring EMT conduit for bends alvanos Electrical 4 02-15-2008 10:30 PM
