Measuring Supply And Return FPM - HVAC - DIY Chatroom Home Improvement Forum
Old 04-21-2012, 06:37 PM   #1
Rewards Points: 280
Measuring Supply and Return FPM
I've completed my crawlspace HVAC upgrade from R4.2 flex to R8 pipe with dampers. Attic is next.
What is the best way to measure air flow FPM? I have a handheld anemometer. Is the best method to remove the deflector grills and place the unit flush with the opening and centered. I have noticed that the air flow measures higher or lower in different locations.
Earnie is offline   Reply With Quote
Old 04-21-2012, 08:13 PM   #2
An old Tradesmen
Rewards Points: 7,396
Are you tying to determine CFM from through the supplies and returns. if so, then the covers must be on, and an average reading across the face is used.
Measuring supply & Return flows lakeresident HVAC 4 11-21-2011 06:12 PM
Closing off HVAC return and supply vents Kulingar HVAC 6 11-15-2011 09:22 AM
Distance between HVAC supply and return vents atlantatd HVAC 4 04-13-2011 08:30 PM
Cold Air Return next to supply duct thebigbbm HVAC 6 09-21-2010 05:51 PM
Supply and Return Issue billybob45 HVAC 4 07-31-2008 09:44 PM
