-   -   Measuring Supply and Return FPM (http://www.diychatroom.com/f17/measuring-supply-return-fpm-141006/)
Earnie 04-21-2012 06:37 PM
I've completed my crawlspace HVAC upgrade from R4.2 flex to R8 pipe with dampers. Attic is next.
What is the best way to measure air flow FPM? I have a handheld anemometer. Is the best method to remove the deflector grills and place the unit flush with the opening and centered. I have noticed that the air flow measures higher or lower in different locations.
beenthere 04-21-2012 08:13 PM
Are you tying to determine CFM from through the supplies and returns. if so, then the covers must be on, and an average reading across the face is used.
