Measure Hydronic Heat Water Temperature - HVAC - DIY Chatroom Home Improvement Forum
Old 01-21-2011, 03:48 PM   #1
WaldenL's Avatar
Rewards Points: 268
Measure hydronic heat water temperature
In short: How does one measure the water temp in a hydronic system -- and don't say "with a thermometer"
Longer version: I'm reviewing my zoning, possible zoning change, and aquastat settings for my heat-only (no domestic hot water) system. Lots of great references about temperature differentials, minimum water temps, "ideal" temp drops across a zone, etc. However, I have no idea how to measure that.
I'd hoped that I could hit the pipes w/a infrared thermometer, at least for a differential reading between supply and return, but no luck. I've got two pipes leading out of my boiler (two zones) and one reads ~190 and the other ~130, and they're both connected to the same boiler, so I know I can't get a good reading that way. Plus the 130 degree one reads about 170 5 feet later on the pipe!
Is there a special thermometer I should have? Something that wraps onto the pipe? Does all pipe conduct at the same rate (assuming it's all 3/4 copper). Lowes/HD/Amazon links appreciated.
WaldenL is offline   Reply With Quote
Old 01-21-2011, 06:11 PM   #2
An old Tradesmen
Rewards Points: 6,142
Dwyer STC162 pipe thermometer.
Unless you have a primary/secondary piping system, you won't get the ideal flow through both the boiler and your heating loops.
The Following User Says Thank You to beenthere For This Useful Post:
WaldenL (01-24-2011)
Why do water heaters have two elements? gp_wa Plumbing 21 02-09-2012 02:56 PM
low domestic hot water flow with tankless coil mike42 HVAC 28 11-24-2011 09:35 AM
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 07:53 PM
Waterfurnace Hydronic Water and Air Heatpump Thermostat Configuration JDForinger HVAC 8 12-05-2010 05:57 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 12:32 PM
