May Be Wrong Wiring!! - HVAC - DIY Chatroom Home Improvement Forum
Old 10-01-2009, 12:11 AM   #1
may be wrong wiring!!
Hi there,
just bought the house - foreclosed, had primitive/broken (old fashion) thermostat, so I replaced with Honeywell RTH7600 thermostat. Old thermostat was giving hot air but now, after replacing thermostat, it doesn't blow warm air. This how I did it:
Black - C
Green - G
Yellow - Y
Oranges - O/B
Red - R (with jumper attached to RC)
White - W (Aux)
Blue - Y2
I've an Electric Heater Cooler furnace, Westinghouse HP33 HZ60 Voltz 20B/240 system, probably 10 years old. PLEASE HELP!!
shunail is offline   Reply With Quote
Old 10-01-2009, 12:28 AM   #2
GetYourShineBox's Avatar
take pictures
GetYourShineBox is offline   Reply With Quote
Old 10-01-2009, 11:33 AM   #3
I'm at work and don't want to spend another night in cold... please help!!
Old 10-02-2009, 03:05 AM   #4
not sure if you solved the problem but i read the install manual for your t-stat and have you made sure you set the t-stat settings to match your equipment? the way you wired it is the correct way to install a heat pump. here is the link for the manual. its possible that t-stat isnt compatible with your model heat pump.
http://customer.honeywell.com/techli.../69-2206EF.pdf
Old 10-02-2009, 06:04 AM   #5
An old Tradesmen
Rewards Points: 6,132
Many old thermostats. Didn't have a common.
Old 10-02-2009, 09:05 AM   #6
sktn77a's Avatar
Rewards Points: 360
Need to know which wires were connected to which terminals on your old thermostat, particularly the orange, blue and black wires. Sounds like you have a heat pump and they are more complicated than a regular system.
sktn77a is offline   Reply With Quote
Old 10-02-2009, 11:12 AM   #7
WELL, problem fixed. Replaced Thermostat, from Honeywell RTH7600 to RiteTemp 6080, works like a charm
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 08:53 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 07:45 PM
Wiring a new bathroom vent fan, what am I doing wrong? leftisright Electrical 10 09-21-2009 05:18 PM
Sunset Basic Home Wiring cover is wrong? CareBear Electrical 3 09-03-2009 11:31 AM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 03:40 PM
