Maximum Base Board Loop Length - HVAC - DIY Chatroom Home Improvement Forum
Old 04-28-2008, 11:50 PM   #1
Maximum base board loop length
A pdf on Bell & Gosset's site called Zoning Made Easy states the maximum length of a 3/4" fin-tube baseboard radiator loop is 67 feet.
Is this the total loop, or just the length of active element fin-tube baseboard?
Mike
Mike Warner is offline   Reply With Quote
Old 04-30-2008, 11:48 PM   #2
Found the answer
The answer is at http://www.heatinghelp.com/heating_howcome4.cfm, it is just the active fin-tube element that is 67ft. The loop length can te at least twice that long.
Mike
remove/replace tile over mud base jfm617 Flooring 1 07-07-2007 06:38 AM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
