Max Distance Of AC Unit To House Wall - HVAC - DIY Chatroom Home Improvement Forum
Old 09-04-2008, 03:06 PM   #1
tar
max distance of AC unit to house wall
The ac unit against the home wall is in way of future deck. Someone recommended moving the Ac unit away from the home wall around 10 feet , so the deck can fit inbetween the wall and ac unit. This solution is causing me some concern. Can the Ac unit be so far away from the house wall? Any help will be appreciated. thanks.
tar is offline   Reply With Quote
Old 09-04-2008, 03:12 PM   #2
1610 CUB's Avatar
Rewards Points: 150
It might be cheaper to relocate the unit to another side of the house, something best done by others.
1610 CUB is offline   Reply With Quote
Old 09-04-2008, 03:28 PM   #3
tar
relocating to other side of the house was the first option but i was told that it would involve more cost and work. I do not intend do this work myself. But should I go with the contractor that wants to move the ac unit away from the house wall?
Old 09-04-2008, 04:55 PM   #4
1610 CUB's Avatar
Rewards Points: 150
I'm not a A/C guy ( I can't fix them) I"m a sheet metal guy. But I have installed 100's of A/c, heat pump, coil,what have you. If they keep the refer lines up and supported all you should need to do is adjust the charge. BTW I have worked this field from 1975-2003!
Old 09-04-2008, 08:55 PM   #5
tar
really appreciate your time and replies. but the last reply got a bit technical for me. did u mean that moving the ac unit around 10 feet away from wall will be okay (as long as all the points you mentioned are taken care of) ?
Old 09-05-2008, 06:26 AM   #6
1610 CUB's Avatar
Rewards Points: 150
I don't know who recommended to you to move it out 10". I did however think you were going to build the deck and then put it beside the new deck, just out 10'. If your thinking of putting it out in the lawn 10'from the house and deck then the answer is No. You need to relocate either down the side of your house or at the end of the deck. ..... j
Studs showing (bulging) through sheetrock js1971 Building & Construction 2 09-03-2008 06:48 AM
Summer House Electrics stu_bill Electrical 9 07-31-2008 10:17 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 03:49 PM
