Mastercool ADA71 Installation Question - HVAC - DIY Chatroom Home Improvement Forum
Old 07-21-2011, 01:29 AM   #1
Mastercool ADA71 installation question
I have completed my very first Swamp Cooler install and so far so good. However, I have a Mastercool single inlet Swamp Cooler Model ADA71. It is a roof mount/down draft styel cooler. Right under the Blower there is a peice called the "cut-off plate" which you can find in the Parts list here http://www.essickair.com/wp-content/...ADA51-7112.pdf
It is part number 12. Anyways, I don't know what it's for. It's kinda like a big flap, except it doesn't really close, it just dangles there. It seems to have holes for screw where I can screw it to the top but then that reduces the size of the opening the air will flow through as it will block off a portion of the opening. If I leave it there it just kinda dangles there in the middle. I'm hoping someone who is knowledgeable with the install of these types of coolers can help me out. Thanks.
Pderbidge is offline   Reply With Quote
Old 07-28-2011, 12:35 AM   #2
Rewards Points: 484
That plate you are refering to needs to be left in there, it helps direct the air out of the blower housing.
It shouldnt flap around unless Champion left the screws out, which wouldnt surprise me.
sammy37 is offline   Reply With Quote
Tags
swamp cooler
new tub installation question tvanharp Plumbing 3 03-13-2011 04:10 PM
Installation of Granite Tile On Shower Walls Spacing Question. taras1 Building & Construction 2 08-04-2010 12:48 PM
casement windows installation versus double hung installation user82106 Building & Construction 2 06-16-2010 06:56 PM
Soffit installation question milano Roofing/Siding 4 02-04-2006 11:13 PM
Wood Burner Installation Question? fisher501 HVAC 1 12-22-2005 10:29 PM
