Old 01-16-2011, 01:09 PM   #1
Master/slave thermostat recommendation
I am looking for a recommendation on a master and slave programmable thermostat combination. The master thermostat is a 6-wire connection and controls my bedroom level. The slave thermostat is a 3-wire connection and controls our upper loft level. Each level is a separate zone. I have a gas furnace and air conditioner, no heat pump. Any suggestions? Thanks.
wcb22 is offline   Reply With Quote
Old 01-16-2011, 04:38 PM   #2
HVAC Installer
I would recommend the Edge Stat from Carrier. The nice thing about this stat, is that it is a multifunction stat that only uses 2 wires. This will give you the option to upgrade your system down the road, such as in a hybrid heat set up.
LukeROttinger is offline   Reply With Quote
Old 01-16-2011, 05:17 PM   #3
An old Tradesmen
Its a nice stat. But a bit over kill for a master/slave zone system.
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 06:40 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-10-2010 12:58 AM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 08:48 PM
Thermostat Recommendation for 95% furnace chetwynd HVAC 11 02-04-2009 01:05 PM
Programmable thermostat with aux and emergency heat recommendation bjwz24 HVAC 3 01-25-2008 05:14 PM
