Old 01-01-2008, 10:02 PM   #1
Masons: Smoke Shelf removal?
Any Masons in the house?
I would like to put an insert into the large fireplace in our 100+ year old money pit. The problem is that the fireplace seems to be very oddly sized and no inserts will fit by my measurements,
The actual opening of the fireplace is quite large....41" wide and 32" high. The problem is that it has a very aggressive smoke shelf. The depth of the fireplace at the base is 20 inches but at about 12" up the back wall the smoke shelf begins encroaching, reducing clearance. Most inserts need the depth to be maintained for at least 16 inches. I don't understand why someone would make this large fireplace (and chimney) with such a shallow area for the actual fire.
Now...if I could remove that smoke shelf and make it a nice box, I would be golden. Can the smoke shelf be easily removed? I realize once you do this you can never go back without a pricey re-build, but my only other option is to get a small freestanding woodstove and just pipe it through the fireplace...an idea I don't really care for.
Advice?
BarryKaraoke is offline   Reply With Quote
Old 01-05-2008, 12:19 PM   #2
OK...how about this. Anyone ever modify their fireplace for an insert?
Old 01-06-2008, 11:14 AM   #3
Eibwen
If its a 100+ year old house the chimney is probably just straight brick without any terra cotta liner.
You can break out the smoke shelf brick but I would strongly suggest having it inspected by a qualified company. Depending on where you are, you may even need a permit to do this.
And due to the age of the chimney and the modifications, I would defintley go with a stainless chimney liner.
Sammy is offline   Reply With Quote
Old 01-12-2008, 05:48 PM   #4
Thanks Sammy!
I found another brand that will fit...more of a "half in half out" design in stead of flush, I will definitely be going with a 8" flexible liner/pipe. We are having the chimney inspected next week regardless to ascertain the condition of the existing flue.
Old 01-12-2008, 07:31 PM   #5
Eibwen
That the way my insert sits... Kinda half in/out but the hearth is still wide enough to make it look o.k.
Let me know how the liner turns out. I'm looking at doing that sometime in the future.
Smoke Detector, Intermittent Chirping Rod Electrical 18 02-23-2008 07:46 PM
GFCI and Smoke alarm circuit issues 00u6166 Electrical 9 10-30-2007 03:41 PM
Shelf for holding indoor plants in dorm room - help Holdthescroll Interior Decorating 5 08-25-2007 01:10 PM
