Marsh Furnance - HVAC - DIY Chatroom Home Improvement Forum
Old 01-04-2008, 06:57 AM   #1
marsh furnance
Help I'm looking for any info and help on a Marsh wall furnance,about 20-25 years old,model no NFO774.Can someone help me?
jacob is offline   Reply With Quote
Old 01-04-2008, 03:48 PM   #2
Realy need some help here,does anyone know of this brand of furnance and where I can find help?
Old 01-04-2008, 04:24 PM   #3
What is wrong with it?
electric or gas?
redline is offline   Reply With Quote
Old 01-04-2008, 05:01 PM   #4
Union HVAC Tech.
If it hit 20yrs, replace it, the life you save my be your own.
bigMikeB is offline   Reply With Quote
Old 01-04-2008, 06:03 PM   #5
This is a gas wall furnance.The problems are that the pilot is on but the burner will not come on.There is a high limit in the top that is not resetting right.Please help.
Old 01-04-2008, 06:06 PM   #6
Union HVAC Tech.
Have you removed the high limit? If thats the problem they are easy to buy and replace.
Old 01-05-2008, 06:13 AM   #7
I took the wires off the high limit and put them together and it still would not light.Is there any way to check the burner or gas valve? Thank you so much for your time.
Old 01-05-2008, 08:06 AM   #8
Union HVAC Tech.
Yes there is a way to check it out, first off you need a volt-ohm meter, and a schematic of the control circuit. Secondly don't guess or assume you know the problem without properly checking through the control circuit. Lastly it makes little sense to put big repair money in a unit that is 20 plus years old on an item that doesn't last much longer than that.
Old 01-05-2008, 12:50 PM   #9
No schematic of the control circuit,that's what I'm looking for,any info on how to troubleshoot this thing.You are probably right about not fixing this old heater and just replacing it,and that's what I'll do for next winter,but we are about thru with winter and I would like to get this thing going to finish off this season.Hope some can help me.How does the circuit ofn a wall heater usualy run?Like from line power to transformer to thermostat to........? where..
Old 01-05-2008, 10:14 PM   #10
Union HVAC Tech.
Power from the transformer runs to the t-stat and the stat sends power to the gas valve circuit through the limit switches. No power to the valve when the stat is made and one of your limits is open.
Old 01-06-2008, 06:35 AM   #11
Thank you so much for the info.I'm going to try to make this thing last for the rest of the winter,then I'll replace it.Thanks to all of you guys that help us so much.
Old 01-21-2008, 11:42 AM   #12
I have a Marsh wall furnace that did the same thing some years back. Seems that the wire used in it was much like lamp cord and it developed enough resistance at a bend to keep it from operating the gas valve. It still read continuity but had a high resistance value. Once I located the high resistance area by probing with a dvom, I cut it out (approx 2") and wire nutted the 2 ends together. It was a great heater til removed last fall for central installation. Still have it in the shed for parts.
jonrotten is offline   Reply With Quote
Old 01-22-2008, 06:24 AM   #13
marsh furnance
Thanks for your reply and very intersting troubleshooting effort.I'm going to go and check as you did and look for high restiance in the wiring.Do you know if any repair info or manuals exist for this unit.Thank you again for the very good insight on this problem.
Old 01-22-2008, 06:09 PM   #14
Union HVAC Tech.
Repair/ engineering manuals are usually only available for @10 years, only 7 is required by law. Maybe you can find one on an antique heater website/forum.
Old 01-23-2008, 06:12 AM   #15
thank you for your reply.I'll look for some of these websites
Furnance burner won't stay on. 2007ken HVAC 11 03-04-2008 12:29 AM
where`s the air adjustment on my old oil furnance SteveS HVAC 4 12-26-2007 12:36 PM
oil furnance "boom" when starting hvac novice HVAC 5 11-21-2007 01:56 PM
Luxaire probane furnance problem jlyle HVAC 4 12-14-2006 12:10 PM
gmp100-3 furnance won't try to ignite davewolf HVAC 5 11-21-2006 03:13 AM
