Manual J - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-19-2009, 12:17 PM   #16
Originally Posted by Yoyizit View Post
Right sizing, or confirming Manual J
This won't work with a variable output furnace.
Toff = 65F, when you don't need heat.
Tper is the 97.5 percentile cold temp, depending on your area, when your furnace is running all the time.
The Slope = (Tper-65)/100
Tout = the average of 5 or 10 outside nighttime temps. Taking the average cancels out the effect of rain, snow, wind, clear weather, etc.
The furnace Duty Cycle in percent at Tout = 100(on time/(off time + on time)) = (Tout-Toff)/slope
Average this over a few cycles.
E.g.
Tper = 5F
so the slope is (5-65)/100 = -0.6
Tout = 29F
so the DC is 100(29-65)/(-0.6) = 60%
If your furnace has this duty cycle at this outside temp. it is right sized.
only works on boilers
hvaclover is offline   Reply With Quote
Old 12-19-2009, 03:06 PM   #17
An old Tradesmen
Rewards Points: 6,112
Originally Posted by hvaclover View Post
Shill and conflict of interest!
He pays to advertise that program here.
Old 12-19-2009, 03:33 PM   #18
tk03's Avatar
Rewards Points: 150
Here is another place for the heat loss.
http://www.comfort-calc.net/home-page.html
tk03 is offline   Reply With Quote
Old 12-19-2009, 03:57 PM   #19
Why?
I used
an always off [zero duty cycle] outside temp. for a furnace at 65F,
and an always on [100% duty cycle] for the design cold temp.
Excel calculates the slope of the temp/duty cycle line with the SLOPE function.
Then you know the duty cycle at any intermediate temp. for a perfectly matched house & furnace & climate by using the equation
Outside Temp = SLOPE x (Duty Cycle) + 65F
or
DC = [Outside Temp - 65F]/SLOPE
T
65.0 < enter Toff
36.0 < enter Tout
DC in %
0 < enter duty cycle
25 < enter duty cycle
-1.16 = calculated slope
65.0 = intercept
100.0 >enter DC
-51.0 = calculated Tout
Tdesign cold temp for Dist. Of Col. Is +14F, not -51F, so my furnace is oversized.
The furnace BTU output doesn't enter into the equation.
If your monthly avg. duty cycle and your monthly avg. outside temp. doesn't match these answers your furnace is undersized or oversized.
Old 12-19-2009, 04:38 PM   #20
Why?
I used
or
T
65.0 < enter Toff
36.0 < enter Tout
DC in %
65.0 = intercept
100.0 >enter DC
The latent hydro electron cyclic nature of the hydrogen atom in the water requires a a correction factor of Pi x Hy/7 xy.
Old 12-19-2009, 05:42 PM   #21
I knew I left something out!
I have to fix this right-sizing-confirmation method.
If you know
your monthly HDD and
your monthly gas usage and
your outside design temp and
your furnace/boiler max input BTU/hr
you can check if your furnace is right sized for your house and climate.
If you know your furnace efficiency
at its monthly avg. duty cycle
you can calc. your house avg. heat loss.
Manual transfer switch to power an existing sub-panel joestewart Electrical 10 11-23-2009 03:30 PM
Thermostat from Manual to Digital trinamillersmit HVAC 5 07-02-2009 10:21 AM
manual J question drewhart HVAC 2 01-31-2009 05:45 PM
needing manual HandyMac Landscaping & Lawn Care 2 07-03-2008 03:26 PM
