Manual D Friction Rate Worksheet - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 01-04-2011, 06:24 PM   #31
Rewards Points: 150
LoLLLL
Now thinking about it. My longest run consist of a 6" flex duct that runs and then connects to a reducer that splits from a 6" into two 4" flex runs. I found the EL for the reducer splitter at 70. But do I count both of the 4" flex runs including the ceiling boxes. Or I only use one of the 4" flex run on the split ?
kilosos2 is offline   Reply With Quote
Old 01-04-2011, 06:35 PM   #32
An old Tradesmen
Rewards Points: 8,174
Just 1 of the 4" runs. The one that would/will be the TEL run. may have to do each separately to see which one is longer.
Old 01-04-2011, 06:48 PM   #33
Rewards Points: 150
Thumbs up
Ok cool, I understand. Thanks so much for all your help Beenthere. I will keep u posted on my results.
Old 01-10-2011, 05:04 PM   #34
Rewards Points: 150
Hey beenthere
here's the break down of my FR.
asp .12 x 100 / 252 tel = 0.04761905
so i rounded it up to 0.05 fr. I havent added the media filter into the equation as I havent decided yet if I am goin to add it yet. For the media filter can the air
handler sit directly on top of the media filter box in which then the media filter box is sitting now on the stand or it usually goes under the metal stand the air handler is sitting on!
If it goes under the stand will I be require to move up the stand so i get more clearance from the floor up for the return.
Old 01-10-2011, 06:06 PM   #35
An old Tradesmen
The air handler can sit directly on top of the media filter housing/box.
Your FR sounds much better now.
The Following User Says Thank You to beenthere For This Useful Post:
kilosos2 (01-10-2011)
Old 01-10-2011, 08:22 PM   #36
Rewards Points: 150
Wink
awesome. Ya I am so happy I finally found the Friction rate. I'll post pics of my install later.
thanks again beenthere
Old 01-10-2011, 08:26 PM   #37
Rewards Points: 150
Beenthere
One more question. When I choose a media filter box. I should pick the size of the bottom return of the air handler? I got a 20x20 opening. So I should get a media filter box that is sized 20x20?
Old 01-11-2011, 03:17 AM   #38
An old Tradesmen
Media filter should be sized for the CFM. If the filter box is the size of the opening. It works out good. if it isn't, then another install method needs to be used. Sometimes a transition from the filter box to the air handler.
Old 01-11-2011, 04:36 PM   #39
Rewards Points: 150
Ok, cool.
Ya, I am going to try to find a media box that will directly fit under the air handler. That way I won't require a transition. Thanks again
Manual transfer switch to power an existing sub-panel joestewart Electrical 10 11-23-2009 02:30 PM
Thermostat from Manual to Digital trinamillersmit HVAC 5 07-02-2009 09:21 AM
Drop Rate on Scott's Drop Spreader SPS-1 Landscaping & Lawn Care 1 04-28-2009 08:24 PM
Toro 7/24 Snowblower - friction wheel Ottawa Landscaping & Lawn Care 1 02-02-2009 08:01 AM
needing manual HandyMac Landscaping & Lawn Care 2 07-03-2008 02:26 PM
