Old 12-30-2011, 05:48 PM   #1
Share |
Manometer brands?!?!?!
What is the best brand to purchase when it comes to manometers? Least and most expensive. I've seen some on ebay from China but I'm no familiar with these brands.
cadam06 is offline   Reply With Quote
Old 12-30-2011, 05:50 PM   #2
as seen on tv
Dwyer u tube works well has been the service mans friend for a while
qbert is offline   Reply With Quote
Old 12-30-2011, 05:57 PM   #3
how
Ya got that right qbert.
Mines 25 years old and still going strong.
how is offline   Reply With Quote
Old 12-30-2011, 06:02 PM   #4
I'm Your Huckleberry
Thanks.
Doc Holliday is offline   Reply With Quote
Old 12-30-2011, 06:02 PM   #5
Hvac Pro
R U a tech and going to be using it a lot? I have a UEI differential pressure type and it gets bounced around in a service van and goes from -40F into houses and survives quite well. Well built and reliable I find the UEI brand and not nearly as expensive as Fluke etc. Fairly compact as some of the larger ones are quite clumsy and won't fit into a furnace well. I have a VERY expensive tiny Testo unit for tight spaces but use this one as my main workhorse. It has a very nice and durable rubber mount around it to absorb shock and a powerful magnet on the back to hold it to the side of a furnace etc.
http://www.ueitest.com/product-em201.html
Old 12-30-2011, 06:15 PM   #6
Houston204's Avatar
I use the Fieldpiece that Doc posted. $120 @ Johnson Supply.
I had a Dwer 1" analog but gave it to another tech when I purchased the Fieldpiece.
Houston204 is offline   Reply With Quote
Old 12-30-2011, 06:22 PM   #7
I paid $1oo plus tax for that Fieldpiece manometer and I got an excellent deal on the Fieldpiece digital refrigerant scale with remote handle. $200 plus tax at Goodman.
I picked up the Fielpiece digital diagnostic pshychrometer new for $140 at Gem-Aire Distribution.
All awesome tools.
Thanks.
Old 12-30-2011, 06:31 PM   #8
Hvac Pro
If U are going to being doing some serious testing of pressure switches and manifold pressure on high efficiency units U need 2 T into the hoses going to the pressure switches and read the "WC while it is operating. 2 do that go 2 your local auto parts store and pickup an assortment of plastic barbed tees they use for vacuum lines for brakes or windshield washers etc.
Old 12-30-2011, 06:32 PM   #9
Houston204's Avatar
I wish Fieldpiece weight scales came in a case.
I've had a Mannix digital pshychrometer for about 8 years now (from Carrier)
By Gem-Air... do you mean ACR?
Old 12-30-2011, 06:36 PM   #10
Houston204's Avatar
Johnson supply has brass tees. Not sure of the size but I think I use a 3/16" x 3/16" by 1/8" tee to tie into the pressure switch.
They never charge me for them. (I probably drop a years salary there every year)
Most common reading for a Carrier 80% is -.66"wc until flame occurs. It then drops to -.44"wc.
Old 12-30-2011, 06:39 PM   #11
Used a yellow jacket analog for many years. Just got a testo 510 and like it a lot. Fits right in my combustion analyzer box and stays protected that way.
Old 12-30-2011, 06:47 PM   #12
Thanks for all of the info. I definitely want a product that will stand the test of time. I'm new to the field so I take in all the questions on this Chat line as to not sound ignorant when I explain issues talk to customers.
If you have any advice, I'm all ears.
Old 12-30-2011, 07:16 PM   #13
Mine came with a soft carrying case with an adjustable shoulder strap. The hand held remote meter is stored (snaps in and a velcro strap) on the underneath of the scale.
These are mine, literally.
Not sure if Gem-Air is Acr, I'll find out one day though.
Thanks.
Old 12-30-2011, 07:17 PM   #14
Houston204, I've always thought that by your screen name you were in Houston. Are you?
Thanks.
Old 12-30-2011, 07:39 PM   #15
Houston204's Avatar
Yep, I work in the River Oaks and Memorial area.
My company is a Carrier FAD, but I mainly work on chill water fancoils in highrises.
Gas furnace brands, which is better, Comfortmaker, American Standard, and Lennox? abefroman HVAC 10 04-22-2014 06:03 PM
Fill and Flush Valve brands gtothek Plumbing 3 10-27-2011 05:30 AM
Rate the brands of Paint nerd_flanders Painting 5 08-07-2009 10:54 AM
Hey Pros: Did my YJ gauge manometer fail me? hvaclover HVAC 20 04-11-2009 06:22 PM
Windows: brands? new frames? frogger Remodeling 8 01-16-2008 11:19 AM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
