Manometer - HVAC - DIY Chatroom Home Improvement Forum
Old 03-01-2011, 03:45 PM   #1
JJboy's Avatar
Manometer
What Digital Gas Pressure Differential Manometer you guys recommend me?
One that comes with pipes and connections.
Thanks All
JJ
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 03-01-2011, 05:44 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,784
UEI makes a good unit. You want a dual port one that measures differential pressures. Testo makes some VERY nice small but very pricey units also. For fittings go to NAPA or a car parts store and buy a bunch of tees etc in the brake repair/brake lines/vacuum lines section and keep them in a tupperware container.
I have a EM-201
http://www.ueitest.com/productList-p...detectors.html
I also have a very expensive small Testo unit for delicate work but use the more rugged UEI for most jobs. Goes from -40F to over 100F in my van and keeps on workin.
Old 03-01-2011, 06:03 PM   #3
An old Tradesmen
Rewards Points: 6,846
I like the Testo 510. You can get it with a kit, to do both gas/manifold pressure checks, static pressure checks, and tee's for check pressure of the inducer of furnaces..
Old 03-01-2011, 06:06 PM   #4
JJboy's Avatar
I was thinking MA Line 12835.
HELP Extend Gas Line mxingislife Plumbing 41 03-14-2013 09:08 AM
Bryant 394J Furnace - Pilot stays ON all the time Davexxx HVAC 17 04-08-2012 06:46 PM
pressure gauge reading for natural gas line robismyname Plumbing 5 10-13-2010 08:39 AM
Hey Pros: Did my YJ gauge manometer fail me? hvaclover HVAC 20 04-11-2009 06:22 PM
Looking for some inexpensive tools for pressure and cfm dac122 HVAC 6 11-22-2008 04:56 AM
