Manifold Hose Blowback - YJ Low Loss Fittings Don't Fit Rheem HP's - HVAC - DIY Chatroom Home Improvement Forum
Old 05-16-2012, 04:34 PM   #1
Manifold hose blowback - YJ Low loss fittings don't fit Rheem HP's
I wanted to check HP subcooling and other operating parameters this week. However my Yellow Jacket low loss hose couplings are too fat for Rheem RPNE HP service valves. I didn't want to take a chance and damage the valve threads or bend down the liquid line coming to the valve so used conventional hoses.
Blowback was probably a diminimus release of about 2oz of refrigerant from disconnecting my 6' high side hose. (yes, I used safety glasses and gloves!!)
I'll probably get some short ball valve hose adapters to have on hand for the next time.
When using ball valve hoses do you generally release the high side hose pressure through the manifold and into the suction line? (assuming the hoses are purged of air). If so isn't liquid refrigerant entering the compressor's suction side bad for the compressor? Or is it too small an amount to even worry about?
Or do you simply leave the hoses pressurized/closed until the next time and not worry about the slight reduction in refrigerant?
hennyh is offline   Reply With Quote
Old 05-16-2012, 04:57 PM   #2
An old Tradesmen
Rewards Points: 6,492
Small amount of liquid at a slow rate won't harm a compressor.
The Following User Says Thank You to beenthere For This Useful Post:
hennyh (05-16-2012)
Theres water where ?? pwa Flooring 28 06-14-2011 08:45 PM
washing machine hose fittings Jc709 Appliances 2 01-20-2011 07:50 PM
Pliers for garden hose fittings Michael Thomas Plumbing 8 01-20-2011 07:49 AM
Hose fittings cellophane Landscaping & Lawn Care 2 06-01-2010 10:50 AM
