Male -male Duct Ends Meet? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-16-2011, 05:02 PM   #1
male -male duct ends meet?
I am installing a new duct line in a crawl space and have to connect an existing male (crimped) to another crimped to make it work.
Do I just open up one of the crimped ends to slide the other in, or is there another way to resolve this?
Thank you!
herennow is offline   Reply With Quote
Old 01-16-2011, 05:23 PM   #2
Have enough pipe to cut one crimped end off? If not you can pound the crimp out but it will look like poo.
The Following User Says Thank You to Marty S. For This Useful Post:
herennow (01-16-2011)
Old 01-16-2011, 05:31 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 2,296
If you are using round pipe you get a 6" piece of the round pipe and leave it open expand it and slip it over both ends like a sleeve. Attach both ends to existing pipe with screws or rivets and seal the joint with metal foil duct tape.
Old 01-16-2011, 05:48 PM   #4
Thanks.
"leave it open expand it" - not sure what you mean by this.
leave it open?
expand it how? slit it?
I'm really close to the answer now... thanks
Old 01-16-2011, 05:52 PM   #5
Hvac Pro
yuri's Avatar
Oy, a picture would be worth a thousand words!
Imagine a new piece of unassembled pipe. You have not closed it and snap locked it together. If you grab it and open it like trying to make it like a flat piece of metal you can slip it around the existing pipes like a bandage. Will not be able to use the snap locks but you can fasten it and seal the remaining gap with metal foil duct tape from HDepot.
Old 01-16-2011, 05:58 PM   #6
PERFECT! Thank you very much!
?an Insulated Flexible Duct - half attached and half unattached ? tran Roofing/Siding 2 06-21-2012 06:25 PM
Planning on New duct work..any feedback... kilosos2 HVAC 28 01-26-2011 09:21 AM
Metal duct or flex? smokey982 HVAC 6 08-06-2010 06:20 AM
adding duct work and outlet jjrbus HVAC 17 05-30-2010 02:13 PM
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 02:33 PM
