| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
How to Install Pipes Under the Kitchen Sink
by Expert Village
I’m Lee. I have a degree in architecture and about ten years construction experience, and today we are replacing the hot water pipe and valve. Now we’ve already installed the valve, which is a two outlet valve- one for the sink and one for... Read More »
Removing a Gas Stove's Flare Fittings
by Expert Village
We need to move the stove out a little bit so that we can gain access to the back of it and what we're going to do next is take off the burner covers and take off this cover plate and then, if you can see, I can stick my hand through the stove here. And... Read More »
How to Prepare Crescent Rolls
by Expert Village
Hi! This is Josiah Owen with Expert Village. Now we're going to talk about our crescents for our franks and Swiss crescents. We're going to need one tube, which is 8 ounces of refrigerated reduced fat crescent rolls. We're going to go ahead and just open... Read More »
How to Do Squat Tubing Exercises
by Expert Village
We're moving on to some leg exercises with our tube. I'm going to ask to stand on the tube with both feet this time. Again, if your feet are close together, you're going to have minimal resistance. If you take them further apart, it's going to be a... Read More »
How to Repair Front Cantilever Brakes
by Expert Village
I'm going to demonstrate for you, how to fix front cantilever brakes, when they get loose, or if you need to adjust them. If they rub against the wheel, for example, that's going to be a problem, so let's go ahead and fix that. This is a special... Read More »
