-   -   Making a blower work with a White Rodgers 50A55-405 Controller (http://www.diychatroom.com/f17/making-blower-work-white-rodgers-50a55-405-controller-35820/)
gegnerx 01-13-2009 01:53 PM
The TRANE XE 80 has a White Rodgers 50A50-405 Controller. Two terminals presently go to the thermostat for heat control.
I wish to allow the Circulating Fan to be turned on/off independently with a separate switching device. The available Y-W-R-G-C terminals on the controllers have the W and R wires hooked to the thermostat.
Which terminals just control the Circulating Fan on that controller Y and G? It's not clear in my reading!
Thank you!
gegnerx
hvaclover 01-13-2009 02:47 PM
You can buy new stat that will do that.
I am assuming you don't want to kill the fan during a heating or cooling cycle do you?
dac122 01-13-2009 04:04 PM
Energizing G will energize the COOL terminal. Is that what you want?
gegnerx 01-13-2009 04:58 PM
White-Rodgers 50A50-405 ability
Thank you for your responses.
I believe the existing thermostat will allow me to activate the fan only for the purpose of moving the air to circulate heat from a fireplace insert; except that the four conductor 18 gauge wiring has been cut to two conductors. I can probably retrieve the other two on both ends, but, I need to know which two wires will allow me to OVERRIDE the heater circuitry (controller) to ONLY allow me to turn on/off the circulating fan.
Thanks!
gegnerx
