Making 2 Zones From 1 - HVAC - DIY Chatroom Home Improvement Forum
Old 09-17-2009, 09:33 PM   #1
Making 2 zones from 1
I have a oil fired hot water radiator system. One bedroom main floor. Basement apt. There are 8 rad. upstairs and 3 downstairs. You know it upstairs to hot downstairs to cold. One 1" pipe runs off the boiler. Each rad T's off and back on to it. Id like to create two zones. Can T off the the main line for down stairs with 3/4 add zone valves for each? Then T off the 3/4 with 1/2 to each rad. Or should I run one continuous loop through the down stairs rad.? I wood like to add a baseboard to one wall. Thanks
radcad is offline   Reply With Quote
Old 09-18-2009, 04:04 AM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
rad, Welcome to the forum
See if this helps:
http://www.thisoldhouse.com/toh/vide...045338,00.html
The new thermostat Richard used is Wireless
Disclaimer
& Stay Safe
.....Bob Lavery
Thinking about making concrete pavers - a few questions Luis C. Building & Construction 16 06-10-2011 05:45 PM
Can anyone help a newbie? - Help with making a book case cosmicmeeting Carpentry 15 05-05-2011 11:39 AM
No heat in 1 of 3 zones, oil burner abacus HVAC 2 01-17-2009 11:42 AM
GE fridge (older model) motor(?) making a lot of noise as it runs, also leak! liileah Appliances 1 06-24-2008 11:32 AM
Making bear totum pole Keith of Ronin Landscaping & Lawn Care 2 03-27-2005 01:22 PM
