Old 01-05-2012, 05:23 AM   #1
Maintenance: Hour Meter On Gas Valve
Had an hour meter laying around and decided to hook it up to the furnace gas valve. Have found out my filters need changing about every 125 hours of run time.
Used single to double disconnects on the gas valve terminals to be able to hook my leads up for the hour meter.
Probably should wire it to the blower motor so that cooling season would be included.
The first two photos are before and the last three are after.
Maintenance: Hour Meter On Gas Valve-11.jpg   Maintenance: Hour Meter On Gas Valve-22.jpg   Maintenance: Hour Meter On Gas Valve-33.jpg   Maintenance: Hour Meter On Gas Valve-44.jpg   Maintenance: Hour Meter On Gas Valve-55.jpg
hammerlane is offline   Reply With Quote
Possible Defective or Incorrect Electrical Meter? MorganB Electrical 10 01-18-2011 10:51 AM
re-soldering a valve joint rtoni Plumbing 9 11-05-2010 11:04 AM
who should pay my gas bill and furnace repair? papashaq HVAC 8 03-09-2007 06:36 PM
Turning valve at water meter KCnorthernCA Plumbing 15 10-23-2006 12:35 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
