Maintenance - HVAC - DIY Chatroom Home Improvement Forum
Old 03-28-2010, 06:45 PM   #1
help
Can I run the vent and fresh air pvc pipes to the side of the house? Have about 15' from the wall to furnace.
frankiepr1964 is offline   Reply With Quote
Old 03-28-2010, 08:49 PM   #2
30 year tech
hvac122's Avatar
Depends on the manufaactures specs and what furnace you have. Way to little info to answer the question.
hvac122 is offline   Reply With Quote
Old 03-28-2010, 09:05 PM   #3
I have Goodman 93% efficient model #GCH90703BXAB. The furnace closet is next to the kitchen. I no want to make a hole in the roof. I wan to know is ok to make the holes to the side of the house. The problem I have is 15' from the wall to the furnace is ok for vent and intake or is to long?
Old 03-29-2010, 05:59 AM   #4
An old Tradesmen
Rewards Points: 7,816
15' is generally ok, as long as you use the right size pipes.
The install manual will have PVC sizes listed.
Old 03-29-2010, 04:20 PM   #5
Thank you
IPE Deck Maintenance Question jason206 Building & Construction 2 02-03-2010 04:36 PM
Oil Boiler Maintenance Piedmont HVAC 4 04-22-2009 03:17 PM
hot water heater annual maintenance: a word to the wise diy888 Plumbing 16 03-19-2009 09:59 AM
Property Preservation, Maintenance & Repai tallenbaugh Off Topic 1 12-13-2008 07:23 AM
DIY seasonal A/C maintenance curls00 HVAC 2 06-05-2008 08:47 PM
