Main Burner Goes Out After Furnace Running 10 -2 0 Mins - HVAC - DIY Chatroom Home Improvement Forum
Old 11-01-2011, 01:58 PM   #1
main burner goes out after furnace running 10 -2 0 mins
I got frustrated with my gas furnace this week after I tried to fix it a couple of times. The details are below:
Gas Furnace: Rheem Criterion RGDG-100BRJR installed 1992. It's probably Rheem Criterion I.
Problems:
1. Thermostat always shows Low Battery - Fixed it with installing new one.
2. Pilot burner was out - I found this problem before turning heat on. Tried to light it a couple of times but went out again after I released control knob. I cleared it and lighted again, it works fine and keeps flaming.
3. No main burner light - when I turn heat on from thermostat, everything seems to work fine but main burner which didn't light. I opened blower door and found a loose wire connecting transformer with control board. I tightened it and turn heat on again, main burner worked. The furnace worked fine for a whole night with on and off several times.
Second day, I thought loose wire was a problem that I already fixed. So I replaced filter with new one and closed burner compartment door. However when thermostat turns it on, main burner lighted and went out again in 10 or 20 minutes. If I opened burner compartment door or blower door, it may get main burner lighted again. If I turn heat off for a while and turn on again from thermostat, main burner works fine. Of course, it will go out in 10 - 20 minutes. Obviously something shuts off gas to main burner while pilot keeps flaming.
Is this Negative Pressure Control problem? I did check the rubber tube, which is clean. When sucking and blow tube, I can hear click. Can I bypass NPC by wiring two wires together to test if it's NPC problem? Why main burner flames just 10 - 20 minutes? Or what else shut off gas for main burner in 10 - 20 minutes? Is it something to be blamed when temp raises in 10 to 20 minutes?
Any input would be appreciated.
marion60 is offline   Reply With Quote
Old 11-01-2011, 03:07 PM   #2
biggles's Avatar
filter is clean as you said just pulling the fan accesss door off and it relights or stay lit says the heat exchanger is going into hi limit trip on the burner...that negative air thing is too deep for a residential furnace you have return air problems.......eye ball that squirrel cage for dirt or dust rounding off the fins.... lack of air causes heat to rise into hi limiting situation main burner shutdown
Old 11-01-2011, 03:23 PM   #3
An old Tradesmen
Rewards Points: 6,142
If you have central A/C, the evap coil may be dirty.
Old 11-02-2011, 10:02 AM   #4
Thanks, biggles and beenthere. Both's suggestions do be what I was worry. I checked return air pipes and tested them with smoking and they seems clear. When I tried to check evap coil, it seems unaccessible as it's surrounded by pipes. I am sure it's dirty as it's 20 years old and I don't think it was cleaned before.
Now it's warm up. Furnace works fine for on/off test for short period. Obviously return air/vents are what I should pay attention to. Thank your both again.
Old 11-02-2011, 10:53 AM   #5
biggles's Avatar
coil check..standing in front of the furnace the "A" looks like this looking at the top of the furnace... go to the back side and cut an inspection hole at the bottom of the "A" go slow "NO DRILLs".i am trying to get you into the area so you can peel that duct like a flap and bend it out to get a mirror and flash light in there you need to see the inside part of the coil where the air comes up from the fan...before any cutting do this....how are the fins on the squirrel cage of the main fan run your index finger on them if there clean the coil will be just dusting not enough to limit the fan during the heating
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 08:01 PM
Furnace makes squeaking/rattling noise after burner shuts off Red Squirrel HVAC 10 11-12-2011 11:39 PM
Main water valve in condo shut off, but neighbors can still hear water running through pipes. cookiebird87 Plumbing 1 12-01-2010 05:43 PM
Tempstar furnace is rumbling when burner is off ?? digitop HVAC 2 12-07-2009 06:39 PM
Natural gas forced furnace - Burner shuts off prematurely scooter100 HVAC 9 01-25-2009 11:46 AM
