Main Blower Is Very Slow On York Diamond 90 - HVAC - DIY Chatroom Home Improvement Forum
Old 07-30-2009, 08:55 PM   #1
Main blower is very slow on York Diamond 90
Greetings:
I have a 9-year-old York Diamond 90 updraft furnace/air conditioning unit.
Model: P3URB10N05501C
Ser: WAMM038102
Yesterday I suddenly noticed that the airflow while the A/C was running was almost zero. I shut it down and went into the basement and could smell what I would call a typical "hot motor" smell. I took off the front covers and found a hot motor with some dust stuck to it but not much else. The lines to the evaporator were frosty from no airflow. The motor turns easily and is not binding up. The wiring looks OK and the air filter is good. This motor is not the kind with a controller mounted on the back of it - everything appears to be inside the main control unit.
After it cooled off I cleaned the dust off of the motor (wasn't that much) and set the thermostat to "fan only." Normally this setting will run the motor at full speed (as far as I can tell anyhow.) I held in the cover interlock switch in and turned the unit on. The motor started to run but only ran at 75 RPM of so - not enough to move much air. I turned it off and tried spinning the motor by hand before starting it again to give it a boost to see if maybe the start capacitor was the problem - no difference.
I searched here and read a few motor related posts but really don't know what to do next. I would rather not throw parts at it without diagnosing further if possible. Should I try replacing the capacitor? Is the control board likely to be bad? The motor?
Thanks in advance - this is my first post and any help is really appreciated!
Andrew S.
dnastrau is offline   Reply With Quote
Old 07-30-2009, 09:00 PM   #2
A weak capacitor will cause a motor to run slow. I would start by replacing the capacitor.
SKIP4661 is offline   Reply With Quote
Old 07-30-2009, 09:02 PM   #3
It ain't a start capacitor. It's a run capacitor. Try that before you change the motor.
hvaclover is offline   Reply With Quote
Old 07-31-2009, 06:53 AM   #4
Thanks guys - I will change the run capacitor and see if that fixes it.
Andrew S.
Old 08-01-2009, 12:50 AM   #5
Thanks again - I replaced the run capacitor and all is well.
Andrew S.
Old 08-01-2009, 01:11 AM   #6
You're welcome.
Where do I send the bill?
Burner does not ignite but main blower motor starts slaptop HVAC 16 02-25-2009 11:58 AM
York Diamond 90 Issues SToronto HVAC 1 03-09-2008 08:35 PM
York Diamond 90 heater Rob P198 HVAC 1 01-26-2008 08:11 PM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 08:18 PM
