Old 06-17-2009, 03:03 PM   #1
Question Magic Chef HVAC water problem
I have a Magic Chef HVAC unit in a hall "closet" that is dripping water by the gallons. It has not been a problem until a few days ago when the unit froze up. We had a tech come out and fill the coolant so the unit is running but there is water coming from around the drip pan and running down into the air intake "crawl space" under the unit. I have cleaned out the drain and can actually see with a flash light thru the pipe all the way to the coil...all is clear. I took the cover off the coil and scraped out a bunch of sludge from the pan (rusted pretty bad) and watched the water level while the unit was running. It does not appear to be overflowing the pan. I guess it could be rusted out but can't see any obvious holes. I noticed the insulating material glued to the inside of the box around the coil is wet down near the pan and at the far end of the coil where it is up against the end of the coil. I don't know if it is normal for that material to get wet or if it might be the result of the freeze up the other day. Any suggestions what to look for? Can the pan be replaced and if so, how do I get it out without damaging the coil? I was wondering if the insulation material might have gotten wet during the freeze up and now is acting like a wick, syphoning the water out of the pan and if so would drying it out with a hair dryer possibly fix the problem?
HELP!
jfriday is offline   Reply With Quote
Old 06-17-2009, 07:07 PM   #2
An old Tradesmen
Good chance its rusted through.
A sheet metal shop can make another one for you.
Get it replaced soon, or you'll end up with mold.
Old 08-15-2009, 11:01 PM   #3
I have a similar problem with my magic chef HVAC unit, does anyone have any recommendations on a new HVAC unit, and how to proceed to replace the old unit? Is it a DIY project? Where can I find good source of information on the old magic chef HVAC electric unit?
DIYUS is offline   Reply With Quote
More On This Topic
You may notice sometime that water is dripping out of a tube in a place that it’s never dripped before, and it’s a pretty annoying thing and it may be getting your porch or door wet. Well, there’s a reason for that. It’s called... Read More »
Your home's heating and air conditioning system (HVAC) is one of the most important elements involved in enjoying your home. Besides providing a comfortable environment, your HVAC also helps to maintain your health by protecting you from extreme... Read More »
Now some other good tips for the sink area, when you're done throwing and your hands are really messy, if you're trying to rinse that all off with water, it might take you a little while, especially where the clay is kind of built up, so I keep a big... Read More »
Room additions are an exciting remodeling project. It's nice to anticipate the enjoyment of extra space in your home. But you want the room to be comfortable year round for maximum enjoyment. There are several ways and means to accomplish this. Read More »
Hi my name is Mathew Christian from Tampa, Florida on behalf of Expert Village. Today I'd like to talk to you about the proper use and maintenance of a pressure washer. When you are done using your pressure washer you want to practice good storage habits... Read More »
Home water pressure problem ATLdrew Plumbing 13 04-24-2009 01:17 PM
frigidaire water dispenser problem svao85 Introductions 0 11-08-2008 10:00 AM
Main water shutoff problem GoodoleBob Plumbing 17 08-27-2008 10:53 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 10:36 PM
hot water problem milo1 Plumbing 0 06-23-2008 03:51 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
