Luxaire Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 04-11-2008, 08:56 AM   #1
luxaire problem
i have a G-UA024514B that i don't think is more than 5 or 6 years old. came with the house. last night i herad it kicking on and off repeatedly and felt cold air coming from the vent. the diagnostic light flashed 8 times indicating a bad gas valve or low gas pressure. anybody know how i can test the valve to see if its bad? or better yet, anyway to fix it if it is?
thanks
freddyhill is offline   Reply With Quote
Old 04-11-2008, 10:53 AM   #2
Couldnt find the error code manual for your exact furnace but on other silmilar models a code 8 says ignition failure. If the burner is cutting in and out, try cleaning the flame rod with light sand cloth and reinstalling it. It is usually a small rod located on the left side of the burners with a single wire going to it. Just be careful if it has a porcelin base not to damage or crack it. Very common problem.
statman is offline   Reply With Quote
Phone Jack Hookup Problem kennykenny Electrical 21 04-09-2017 10:36 AM
GMP100-3 Problem hansim4 HVAC 2 12-13-2007 03:55 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
luxaire furnace problem Joeymartin HVAC 1 12-14-2006 04:58 PM
Luxaire probane furnance problem jlyle HVAC 4 12-14-2006 11:10 AM
