Old 12-11-2006, 12:13 PM   #1
Luxaire probane furnance problem
I have a luxaire propane furnance installed 5 years ago. it has always worked good. this year it starting giving us trouble with 4 beep codes of High Limit Switch. I called a local tech out and replaced the High Limit Switch and it worked great for about a week. since he as came back out and installed another new and it lasted only 2 days. We are now running the furnace with a jumper wire to bypass the High Limit Switch. What could cause the unit to keep blowing High Limit Switch?
jlyle is offline   Reply With Quote
Old 12-11-2006, 12:40 PM   #2
Thoroughbred Mopar Man
Hi jlyle
First thing you need to do is remove that jumper wire before you burn your house down or destroy your heat exchanger. The second thing you need to do is fire your HVAC company and find a good one. The problem you are having could be a plugged air filter or blower motor not running up to speed or a plugged evaporator. There could also be insulation loose inside the duct work restricting the airflow. The limit switch is there in case any of the metioned happens. Find yourself a good HVAC company and have them fix the problem.
Good luck
Rusty
#CARRIERMAN is offline   Reply With Quote
Old 12-12-2006, 09:01 PM   #3
Electrical Engineer
Never bypass any safety device on a furnace. Everything is there for a reason.
rakes9720 is offline   Reply With Quote
Old 12-12-2006, 11:29 PM   #4
747
registered
747's Avatar
Who put the jumper wire on if the hvac guy did i would think he could have his license suspened for that couldn't he CARRIERMAN.???
747 is offline   Reply With Quote
Old 12-14-2006, 12:10 PM   #5
Hi Guys
Not sure in the state this person lives in and what the laws are there. But if the heat exchanger fails or the house is burned down, this particular company just assumed the liability for the problem, if they were the ones that installed the jumper wire. If the jumper was installed by the homeowner under the instruction of the company, the same rules apply. Either way it could end bad for the HVAC company.
Rusty
New High Efficiency Furnace Problem Buster 567 HVAC 8 12-13-2010 09:36 PM
furnace problem captjack HVAC 8 11-23-2007 12:15 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
luxaire furnace problem Joeymartin HVAC 1 12-14-2006 05:58 PM
A/C Thermostat Problem therumblefish HVAC 7 11-01-2006 09:08 PM
