Old 02-11-2004, 09:21 AM   #1
KS_Rehabber's Avatar
LUXAIRE gas furnace shutting off
The thermostat has to be reset to make it work again. This usually happens about twice a week.
I'm thinking it may be the ignition module or the flame sensor. Any ideas?
Thanks!
KS_Rehabber is offline   Reply With Quote
Old 02-17-2004, 10:20 PM   #2
Thanks!
You first need to see what the furnace is doing when it locks out
Is it cycling 3 times then locking out? Flame sensor
Or running for a while and shutting off could be module, weak ignitor
kachas is offline   Reply With Quote
Old 04-30-2004, 11:20 AM   #3
Unregistered
Guest
Posts: n/a
Thanks!
the furnace should have a small plastic window on the bottom panel of the furnace the next time it locks out you should check if it has a flashing light and count the number of times it flashs this is a self diognostic and the codes will be listed in your owners manuel. If this is a 90 + hi-efficiency furnace you shoul have a tee installed in the horizontal line close to the furnace with a looped plastic hose attached to it to catch excessive condensate from comming back down the pipe and causing look-outs to happen hope this helps
if you need more info let me know
Old 05-29-2004, 12:23 AM   #4
notlev
Guest
Posts: n/a
Unhappy
Can anyone tell me if there unit is really loud, or is just mine. And do you like the product or not.
Old 08-23-2004, 04:56 PM   #5
Unregistered
Guest
Posts: n/a
Thumbs up
My unit has been decent, once luxaire addressed the ignitor issue, the way they had the other ceramic ignitor positioned, if a spider or anything came in contact it burned out, i was going through one ignitor a year, They made a design change a couple years ago, and i havent had to change one since.
Need Luxaire Forced Air Furnace Wiring Diagram misticvillage HVAC 7 04-15-2009 05:09 AM
luxaire furnace problem Joeymartin HVAC 1 12-14-2006 05:58 PM
Luxaire furnace fails to fire cheesegrump HVAC 1 01-10-2006 08:36 PM
luxaire furnace tbristolb HVAC 2 03-30-2005 10:53 AM
Luxaire Furnace mobear HVAC 1 03-13-2005 12:54 PM
