Hi, my Luxaire gas furnace is leaking small amounts water from the bottom of the pan the inducer motor bolts too. I checked the hoses and they are all clear and clamped. I had this problem a few ago and I pulled the pan and made a new cork/rubber gasket from material I got at the autostore. It worked for a while but I don't think that material is really suited for water. I remade the gasket and it is leaking again. What should I use to repair/reseal this. I was told the part was no longer available. I inspected for cracks but did not see any. The leak is pretty obvious, is seaps out of the bottom edge of that pan.
I was thinking of trying a liquid gasket but don't want to make a big mess. Is there some rubber sealing material I can use? Any help appreciated.
The ultra copper will work fine. I have used it for automotive gaskets which got much hotter then your part will get. Put the silicone on each side of your gasket and screw it back on . Need to the leave the furnace turned off untill it cures.
Should I go with the cork/rubber gasket material or this rubber/paper material I also have. The cork seems to absorb alot of water and wick the water out of the seal. I bought some other material that is more like a rubber/paper which is what I'm currently using. It leaks more than the cork did. I guess it is thinner material so maybe it didn't seal well. So your saying use the gasket with RTV bead on both sides of gasket? Thanks for the info.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
