Luxaire Gas Furnace Blower Runs Continously - HVAC - DIY Chatroom Home Improvement Forum
Old 12-29-2011, 10:59 AM   #1
Luxaire gas furnace blower runs continously
Model G8T11520UHC11A
After I reset the gas control valve (see attached pic) the furnace ignites and blower runs fine for about a day. Then about a day later, the blower continues to run, the thermostat clicks when it reaches the desired temp. When I take cover off, there is no flame, the blower is running. I try to turn the thermostat to OFF, blower still runs. The furnace never ignites until I do the reset (disconnect power, flip the gas control valve from on to off, then back to on, reconnect power).
I hope I explained this clearly.
BayouDawg is offline   Reply With Quote
Old 12-29-2011, 11:26 AM   #2
Rewards Points: 582
its tripping high limit switch....are filter clean...do you have a/c if so could be dirty coil...also i noticed flex pipe inside burnner box....thats a no no..should be pipe solid till out side of cabinet... sorry i have to leave so others are around....ben
Old 12-29-2011, 12:12 PM   #3
Attachment 43189
Attachment 43190
Attachment 43191
Did you check for a fault code on main circuit board?
as Ben stated it could be off on the high limit or it could be in a lock out state due to a dirty flame sensor, the blower is running because there was a call for heat, it does not know that the cycle never fully initialized. flame sensor is a steel rod on left side of burner rack, remove it clean it with steel wool, Emory cloth or fine sand paper.
harleyrider is offline   Reply With Quote
Old 12-29-2011, 05:57 PM   #4
I just found out where to look for fault code. So waiting for it to fail again.
Thanks for all the advice!
Old 12-29-2011, 06:08 PM   #5
I'm Your Huckleberry
Rewards Points: 2,270
Not that it matters but your unit will fail inspection and is unsafe as is. You have a gas flex line going directly into the furnace, it is supposed to be steel pipe from the gas valve (inside furnace) through the furnace and flex connected outside.
Serious fire hazard. Flex lines go kabOom!!
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
ben's plumbing (12-29-2011)
Blower problem on American Standard Freedom 90 furnace ekimmo HVAC 8 08-27-2011 09:13 PM
Blower motor: Emerson to GE threeonesix HVAC 12 08-25-2011 03:59 PM
Blower motor in old bryant furnace runs constantly GetYourShineBox HVAC 2 07-20-2010 07:49 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
