Luxaire Furnace Won't Fire - HVAC - DIY Chatroom Home Improvement Forum
Old 12-06-2010, 12:58 PM   #1
Hi Everyone. I have a Luxaire furnace that will not fire. The computer board was replaced about a year ago and now there is a flashing red LED light on the board. According to the error codes on the back of the furnace door, 3 red flashes means that the pressure valve switch is stuck open.
Does anyone know what this kind of repair should cost me? Is it difficult to replace on my own? Are there any pitfalls if I decide to do it on my own or do you recommend I get a professional? Does anyone have a referral they can offer? The house is in Redford Michigan, Wayne County.
Any info would be helpful!
Thanks,
Chuck
ChuckAnderson is offline   Reply With Quote
Old 12-06-2010, 02:22 PM   #2
first make sure the fan motor the hose connects to is running,
pull the hose off the switch. blow in to the hose.
remove switch from furnace and shake it like you are trying to remove water from it.
reassemble and see what happens.
hvaclover is offline   Reply With Quote
The Following User Says Thank You to hvaclover For This Useful Post:
greenorchid (09-30-2012)
Old 12-06-2010, 02:29 PM   #3
If I need a new switch, do you know where I can get one in the area?
Old 12-06-2010, 02:39 PM   #4
Whole bunch. an inter net search will get you to the closest one.
i haven't worked the west side in twenty years. Places I bought from are all gone.
But switches don't usually go bad. do as i said first. repost for more info,
Old 12-07-2010, 07:48 PM   #5
Luxaire Pressure Switch
Well, I did replace the switch. But, the good old LED light still flashes 3x telling me that the pressure switch is stuck open. Well, it cannot be stuck open, it is new and when I suck on the hose attached to it, you can hear the switch open and close.
Does this mean I need another computer board? What does it mean and why does it have the same error code as before even though I have a new switch? None of this makes sense.
HELP!
Old 12-07-2010, 07:52 PM   #6
Replaced Luxaire Pressure Switch, but error code still says bad?
Well, I replaced the pressure switch on my Luxaire furnace because the LED flashes 3x and it says the pressure valve is stuck open. But, it cannot be stuck open, it is new and when I suck on the hose attached to it, you can hear the switch open and close.
Does this mean I need computer board? What does it mean and why does it have the same error code as before even though I have a new switch? None of this makes sense.
HELP!
Old 12-07-2010, 07:53 PM   #7
AKA HVACTECHFW
Rewards Points: 1,208
it means a couple of possibilities 1: the pressure port that the hose attaches to on the draft motor is plugged---remove hose from draft motor and using a paper clip or small drill bit, clear obstruction in pressure port on draft motor or 2: you have a blocked flue. to TEST for this, remove flue from furnace and attempt to run furnace, if all is a go, then flue is blocked.... DO NOT RUN FURNACE WITH OUT FLUE ATTACHED!!!!!
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 12-07-2010, 08:20 PM   #8
HELP!
Does the ind. Motor run (little black motor were pressure switch is attached) if so motor may not be turning fast enough. Order of operation call for heat ind. Runs makes switch and hot surface ing. glows opens gas valve and you have ing. Checks clogged vac hose bad motor or pressure switch or bad board.
Hixheat1 is offline   Reply With Quote
Old 12-07-2010, 08:31 PM   #9
Also make sure the inducer motor is clean. Via housing not full of rust or debri, this will slow the motor down.
Old 12-07-2010, 08:41 PM   #10
Hvac Pro
yuri's Avatar
Rewards Points: 1,404
Check the port on the inducer fan where the hose from the press switch attaches to for blockage. Ream it out with a paper clip or small drill bit. Otherwise you need a manometer to check how much draft/suction you have from that fan and whether it is enough to close the switch. Remove the vent pipe from the top of the furnace and look inside the ventor fan for a dead bird or feathers. They fall down the chimney and can block it. Try fire the furnace up w/o the vent pipe on for a few seconds. If it fires up then check the chimney for blockages.
Old 12-07-2010, 08:46 PM   #11
Originally Posted by yuri
Check the port on the inducer fan where the hose from the press switch attached to for blockage. Ream it out with a paper clip or small drill bit. Otherwise you need a manometer to check how much draft/suction you have from that fan and whether it is enough to close the switch. Remove the vent pipe from the top of the furnace and look inside the ventor fan for a dead bird or feathers. They fall down the chimney and can block it. Try fire the furnace up w/o the vent pipe on for a few seconds. If it fires up then check the chimney for blockages.
Nice call don't allow furnace to run long with flue not connected co bad stuff
Old 12-07-2010, 09:09 PM   #12
AKA HVACTECHFW
its like there is an echo, see chuck's other post labeled Luxaire Furnace Won't Fire
good to know we all have the same ideas
IT IS WHAT IT IS
Old 12-07-2010, 09:30 PM   #13
Nice got to love the diy people just be safe. Or call a pro.
Old 12-07-2010, 09:32 PM   #14
An old Tradesmen
Rewards Points: 6,464
Merged the threads.
Old 12-07-2010, 10:19 PM   #15
AKA HVACTECHFW
Originally Posted by beenthere View Post
Merged the threads.
thanks beenthere
IT IS WHAT IT IS
Changed gas ball valve and York furnace won't fire, please help. philsoldat HVAC 35 11-03-2010 12:12 PM
luxaire furnace blinking red three times amy0610 HVAC 1 10-04-2010 11:17 AM
my furnace wont fire... please help! chrider88 HVAC 7 01-22-2010 10:43 PM
Luxaire furnace fails to fire cheesegrump HVAC 1 01-10-2006 08:36 PM
Luxaire Furnace mobear HVAC 1 03-13-2005 12:54 PM
