| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
Sprint Car Cockpit Anatomy
by Expert Village
Were going to talk about the cockpit. There's quit a few elements to the cockpit. The number one would be the steering wheel which pops on and off with this lock. This locks the steering wheel when it is up, and unlocks when it is down. It just slips on... Read More »
How to Start a Sprint Car
by Expert Village
In this clip were going to talk about the on and off switch and our clutch, so this is a direct drive so, if its in gear its in gear, there?s no shifting or anything, and if its out of gear its out of gear, its in gear now, just like that, and this is... Read More »
Starting the Car to Check the Oil Level After an Oil Change
by Expert Village
Hi, I'm Mark Sullivan for Expert Village and today we're going to teach you how to change the oil in a standard internal combustion automobile engine. We're going to now start the vehicle and check and then what we're going to do is when the motor starts... Read More »
How to Check Engine Oil on a Sailboat
by Expert Village
Okay, one last thing you want to do before you leave the dock is to check your water and oil. Go ahead and open up the lid. Very gently sit it up against the side here, because we don't want to scratch the varnish. Check the oil, we'll pull the stick out... Read More »
How to Troubleshoot Split Phase Motors
by eHow.com
If your appliance is not working properly and has a split phase motor, you may be able to repair the problem yourself. Resolving the problem with your split phase motor can be fairly easy once you determine what the problem is. Read More »
