Old 11-13-2008, 10:05 PM   #1
Default Luxaire Furnace doesnt always fire
I have a luxaire furnace model # G/UA036SA. Here is the process of my problem:
1. Furnace comes on.
2. Exhaust fan runs(I assume to evacuate any gas buildup)
3. Exhaust fan still runs 3 to 5 mins then ignitor glows, audible click sound(safety valve opens), gas enters but does not always light.
4. When gas starts to enter ignitor stops glowing, no ignition, and safety valve closes.
Is this valve issue or a fan timing issue? It seems like the ignitor should glow longer for the gas to ignite off of it.
sdise is offline   Reply With Quote
Old 11-13-2008, 10:20 PM   #2
thats along time from fan start to valve opening but id try cleaning the flame sensor it looks like a silver piece of metal usually coming from the bottom of the burner area and sticks into one of the flames created by one of the burners also usually has one single wire on it (sometimes white) just lightly sand it or use steelwool and reinstall it making sure its completely engulfed by the flame when its lit if it isnt the burners need to be cleaned let me know what happens...ken
After rereading your problem id suggest you remove your burners and wash them out with a hose or kitchen sprayer in kit sink if they are dusty gas cant flow across the pilot rail as well and gas cant get to the ignitor When the furnace dosent see a flame on the first attempt it usually will run the inducer for a prolonged amount of time on subsequent attemts to purge the heat exchanger of raw gas. still follow above advise to clean sensor
kennzz05 is offline   Reply With Quote
Old 11-14-2008, 07:32 AM   #3
An old Tradesmen
A. Thats the model number of your A/C coil. Furnace mod number will be inside the furnace.
B. Sounds like a problem with the inducer, or venting. Taking too long to establish good draft.
Old 11-16-2008, 01:31 AM   #4
I had a similar problem with my American standard Freedom 90 furnance and the fix was to increase the W.C. from 8 to 10 for my propane run furnace.
jabass is offline   Reply With Quote
Old 11-19-2008, 09:46 PM   #5
Default Correct model number found!
Thanks for the info of where to look. Model number is PCMU-LD12n076B. Cleaned the igniter and it broke.
Replaced the igniter last night with a new one and the problem is still happening.
Old 11-19-2008, 11:02 PM   #6
ignitors dont get cleaned(guess you figured that out)
did you remove and wash the burners
is there a flame sensor, metal rod with a single wire on it opposite end from ignitor?if so thats what gets cleaned
Old 01-31-2009, 02:30 PM   #7
Default just got it fixed
I had a similar problem last night, guy came and fixed it, said it was the exhauster, charged me $600, trying to figure out if he ripped me off
info is offline   Reply With Quote
Old 01-31-2009, 03:00 PM   #8
old pro
Wash out or blow out the burners with compressed air.
Old 01-31-2009, 06:11 PM   #9
An old Tradesmen
If its working, and you have heat.
He didn't rip you off.
More On This Topic
Hi! My name is Jeff Thompson for Thompson Air hot air balloon rides and I am here with Expert Village and today we are going to talk about the bottom end. The bottom end is what pilots refer to as their basket of a hot air balloon. Anything that goes... Read More »
Hi I'm Betty Ingham on behalf of Expert Village. We would put little things all around that. As in Christmas ornaments or some more smaller patterns or some more smaller items. Now we try to utilize every step, every piece, every inch of our kiln because... Read More »
Hi, this is Dave for Expert Village. Today we're going to make what we call a stuffed Cajun swamp log. So now we're going to do an extra step here. We're going to put a bell pepper right on the burner so it can scorch, if you have gas it works great too... Read More »
Before you call someone to come fix your furnace, you may want to find out what's wrong. Read on to learn how to check your furnace for any possible malfunctions. Read More »
A worn barbecue grill burner can ruin your outdoor dinner. If your barbecue grill burner produces a yellow or orange flame, causes too much smoke or just cooks unevenly, you can probably solve the problem with a new burner. An inexpensive burner will... Read More »
Luxaire furnace flame out Tuckrb HVAC 10 03-19-2009 10:52 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 03:45 AM
luxaire furnace wont fire patobrien HVAC 2 11-05-2007 12:02 PM
Luxaire furnace fails to fire cheesegrump HVAC 1 01-10-2006 09:36 PM
Luxaire Furnace mobear HVAC 1 03-13-2005 01:54 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
