Old 10-06-2009, 05:11 PM   #1
Luxaire furnace blower will not shut off
Have a Luxaire furnace model number FG9B08012UP11B, the problem is the blower will not shut off.
This past summer on a 85+ degree day the blower came on by itself, the therm. was set on 50 degrees. The power to the furnace was shut off.
I have checked all the connecters, unplugged and plugged in all the tubes to the to check for dirt and water and found none.
When I turned the power back on the blower did not run. I set the thermostat so it would run and it operated properly until the blower should have shut off and it stayed running. Turned the power off, went thru the connectors and all that again and the the same thing happened.
This furnace is in my mothers house and I did not know about any of the problems until a few days ago.
Any help is appreciated
danaugstin is offline   Reply With Quote
Old 10-06-2009, 10:14 PM   #2
It sounds like the fan relay is sticking. Maybe a problem with the t-stat, maybe the control board. It's hard to say.
Flashheatingand is offline   Reply With Quote
blower won't shut off on new gas furnace johnny67 HVAC 36 09-14-2009 10:23 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
Bryant Furnace Blower Running Constantly GhostBuster HVAC 15 11-30-2008 10:08 PM
Newmac furnace blower won't shut off dsgreer HVAC 2 11-03-2008 02:23 PM
Oil furnace won't shut off tef HVAC 3 11-13-2007 09:43 PM
