Luxaire Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 11-16-2012, 12:27 PM   #1
Luxaire Furnace
My gas furnace blower motor will not operate when the tsat is in AUTO. It will operate in RUN. The furnace does light up in both modes but only shutdown when tstat in AUTO.
Also, where can i get the service manual or wiring diagrams on this furnace.
Luxaire Furnance model: PCMU-LD16N095B
205HVAC is offline   Reply With Quote
Old 11-16-2012, 05:19 PM   #2
Rewards Points: 1,214
Sounds like a defective fan control not turning on the fan when it reaches the proper run temp and this is causing the over temp safety to shut down the burners. The reason it runs when in the run/on is the fan is started by the cooling relay not the fan control.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 11-17-2012, 08:26 AM   #3
Rewards Points: 460
Wiring diagram often on back of blower door.
diyorpay is offline   Reply With Quote
Luxaire Gas furnace bolesrs HVAC 6 12-19-2016 03:11 PM
1995 luxaire furnace issue neastguy HVAC 15 11-09-2012 08:43 AM
Quote for new furnace. Reasonable? dengle HVAC 16 03-04-2012 08:01 AM
regulator for luxaire high effiencent propane furnace stainless bay HVAC 2 05-01-2011 08:27 PM
Luxaire furnace blower will not shut off danaugstin HVAC 1 10-06-2009 10:14 PM
