Luxaire Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 11-08-2012, 10:10 PM   #1
Rewards Points: 31
luxaire furnace
my test red light flashes 3 times over and over again says pressure switch is stuck open what and where is the pressure switch what can be done need help
thank you
upnorthdennis is offline   Reply With Quote
Old 11-08-2012, 11:51 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
See the tube which connects to the pressure switch to the draft inducer motor? Carefully remove it and stick a straightened out paper clip into both of those ports. You may have some sediment stuck in there keeping the switch open.
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
carmon (11-09-2012)
Old 11-09-2012, 12:25 AM   #3
The inducer and pressure switch are both in the burner compartment. Usually there is a hose running from the draft inducer back to the pressure switch.
ModelAFan is offline   Reply With Quote
Old 11-09-2012, 08:51 AM   #4
weinstall.ca
definately the pressure switch giving you problems.
make sure the hoses are not cracked and are tight.
Also make sure there is no dirt on venter opening to ventor and pressure switch.
We do alot of repairs like this in Tornto.
allan is offline   Reply With Quote
Old 11-09-2012, 07:11 PM   #5
Rewards Points: 31
pressure switch
ok i have checked the valve seems ok i cleaned end going in hose is good and it is working today as i blew through hose should i replace that pressure switch
Old 11-09-2012, 08:18 PM   #6
Rewards Points: 196
Dont put paperclip into port of the presure switch, could put hole into diaphram of pressure switch.
HVACTECH96 is offline   Reply With Quote
Old 11-09-2012, 09:21 PM   #7
Rewards Points: 31
presssure switch
thanks should i just replace it i did pull off hose hooked vacume tp it it seems to work hose is good
Luxaire Gas furnace bolesrs HVAC 6 12-19-2016 03:11 PM
1995 luxaire furnace issue neastguy HVAC 15 11-09-2012 08:43 AM
Quote for new furnace. Reasonable? dengle HVAC 16 03-04-2012 08:01 AM
regulator for luxaire high effiencent propane furnace stainless bay HVAC 2 05-01-2011 08:27 PM
Luxaire furnace blower will not shut off danaugstin HVAC 1 10-06-2009 10:14 PM
