Luxaire Acting Up - HVAC - DIY Chatroom Home Improvement Forum
Old 03-01-2009, 10:37 PM   #1
Luxaire acting up
I have a Luxaire model # PBNULD10N0600
When my thermostat is calling for heat, it doesn't kick on.
The solution so far I have found is, to take cover off bottom panel, hold in the panel switch, tap on the box which I assume is all the relays, etc. And it will kick on every time.
Was going to call repair man thought I'd give this a try.
jarau is offline   Reply With Quote
Old 03-01-2009, 10:46 PM   #2
HVAC / Plumbing
How old is this unit ?? Check the wiring.. Mabe loose connection
kenmac is offline   Reply With Quote
Old 03-02-2009, 07:05 AM   #3
Luxaire acting up
The unit is approximately 18 yrs old.
Have checked all the connections and even cleaned the wire tabs up.
Still same problem.
I'm thinkin its some sort of relay malfunction?
Tags
electrical , furnace , luxaire , luxairefurnace , pbnuld10n0600
Luxaire Furnace Issues ElecEngineer262 HVAC 5 03-15-2009 12:02 PM
Kenmore ice maker acting strange BJLower Appliances 3 10-25-2008 12:14 AM
Luxaire heat pump wiring diagram StevieRay HVAC 5 07-02-2008 11:08 AM
Luxaire Furnace mobear HVAC 1 03-13-2005 12:54 PM
