Luxaire Acclimate 8.t Will Not Blow - HVAC - DIY Chatroom Home Improvement Forum
Old 12-27-2011, 08:32 AM   #1
Luxaire Acclimate 8.t will not blow
My furnace will not blow. The pilot will light, gas will flow to the flues, then stop. This cycle repeats 3 times, then stops. My diagnostic reading blinks 7 times. This says ignition lockout due to retries. Please help
kel4rest is offline   Reply With Quote
Old 12-27-2011, 08:48 AM   #2
I'm Your Huckleberry
Rewards Points: 2,270
find and clean the flame sensor.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 12-27-2011, 08:50 AM   #3
All you need is a rough dish washing pad to scrub it with, not sand paper.
You do this if the flames are coming on for just a split second and then turning off.
Thanks.
The Following User Says Thank You to Doc Holliday For This Useful Post:
kel4rest (12-27-2011)
Old 12-27-2011, 09:16 AM   #4
WELL I'LL BE DOGGONED!! That did the trick! I have just found my new favorite website for home improvement and repair.. Two thumbs up for you Doc Holliday!!
pilot lit, burner won't ignite unless I blow on pilot light rl5 HVAC 7 01-06-2011 09:08 PM
Luxaire Acclimate 9M Natural Gas Problem Trailwalker HVAC 9 12-18-2010 04:25 PM
Need help with Luxaire trouble code DustinP HVAC 22 12-07-2010 05:37 PM
Luxaire heat pump wiring diagram StevieRay HVAC 5 07-02-2008 10:08 AM
blow power of vents mcvane HVAC 5 08-11-2007 03:28 PM
