Lux Thermostat Help - HVAC - DIY Chatroom Home Improvement Forum
Old 09-30-2012, 11:50 AM   #1
Lux thermostat help
I am installing the Lux LX9600TS with an American Standard heat pump.
The cooling mode works fine, but I can not get the heating mode to work. The unit was previously operating with a Honeywell thermostat, with an orange wire connected to a terminal labelled "O/B" on the thermostat.
I have the wires hooked up as following:
Green to "G"
Orange to "O"
Yellow to "Y"
Red to "RC"
White to "W2"
Brown to "C"
Jumper from "RC" to "RH"
Jumper from "Y" to "W"
Gas/Electric switch "Down" (Which should be electric based on what is printed on the circuitboard)
Switch 1 "On"
2-6 'off'
7 'on'
8 'off'
Additionally, the unit makes a humming sound whenever the backlight is on... is this normal?
emmd2001 is offline   Reply With Quote
Old 09-30-2012, 01:06 PM   #2
Houston204's Avatar
Rewards Points: 556
Did you allow 5 minutes for the heat to start?
Does the fan run in heat mode?
Houston204 is offline   Reply With Quote
Old 09-30-2012, 01:32 PM   #3
Yes, unit sat for > 15 minutes with no response.
The fan does NOT turn on in heat mode.
Old 09-30-2012, 02:40 PM   #4
Houston204's Avatar
Rewards Points: 556
Move the gas/elec switch up.
The manual states that down = gas.
Old 09-30-2012, 03:02 PM   #5
Tried that as well, still no response. Thought maybe the instruction was backward as it contradicts what is printed on the circuit board for that switch, but it doesn't work either way...
Old 09-30-2012, 03:06 PM   #6
AKA HVACTECHFW
Rewards Points: 1,208
return the Lux and get a Honeywell thermostat
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
ben's plumbing (09-30-2012)
Old 09-30-2012, 03:08 PM   #7
Why? That doesn't help much...
Old 09-30-2012, 03:17 PM   #8
AKA HVACTECHFW
Because Lux is not a good thermostat manufacturer. Test your system operation by touching red and green together to make sure your blower comes on.
IT IS WHAT IT IS
Old 09-30-2012, 03:32 PM   #9
Yes, the fan does turn on with that.
The unit works fine w/ AC or even just the fan switch on, but does nothing in heat mode...
Old 09-30-2012, 03:38 PM   #10
AKA HVACTECHFW
bad thermostat............... again, buy a honeywell.
IT IS WHAT IT IS
Old 09-30-2012, 08:26 PM   #11
Rewards Points: 582
did you bypass thermostat for heat mode at control board to see if it will fire up... this will tell you if stat is problem...
Old 09-30-2012, 08:34 PM   #12
AKA HVACTECHFW
Ben, it is a heat pump so there will be no "firing up".
Op, if you want to bypass the thermostat to check for proper operation you would need to jumper R to Y and G. This will simulate a call for first stage heating (heat pump in heating mode)
IT IS WHAT IT IS
Old 09-30-2012, 08:38 PM   #13
Rewards Points: 582
helps to read all before opening mouth...my bad thanks.... out here in pa used to furnaces firing up....not going into heat mode......
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 09:43 AM
Thermostat for electric baseboard wiring help needed vae_victis HVAC 10 01-05-2012 11:53 AM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 05:32 PM
Thermostat issues rathipon HVAC 4 01-29-2011 12:46 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-10-2010 12:58 AM
