#1 |
LUX digital stat Trane XE80 intermittant problem
I just moved into this house and replaced the original Honeywell analog stat with the LUX programable stat. I used the 2 wire config, since there are only 2 wires from the furnace to the stat. It has been working fine for the last month except on 2 occassions that the furnace did not turn on. This does not happen all the time. When it does happen and I "manually" increase the thermostat the furnace turns on.
Example 1) This morning I noticed the temp was 65 the stat was set to 68, but the heat never came on. When I turned the stat to 69 the heat started. I have it programmed to go to 68 about an hour before I get up. Example 2) The last time this happened I turned the stat down while the furnace was on. When the temp went below the stat setting the furnace did not turn on. Again I had to manually adjust the stat and everything worked fine, until today. Should I suspect the stat or the furnace? |
#2 |
Probably just a bad stat, Lux is not the best brand out there. Go over to lowes or H.D. and grab a good Honeywell stat. Make sure you shut the power off first so you dont fry your transformer or blow a fuse.l
#3 |
Got a Honeywell will return the LUX. Anyone else have an opinion?
My concern is that the furnace control board is getting "confused" when I interupt the heat on cycle by turning down the stat. |
#4 |
An old Tradesmen
The furnace doesn't know the difference between you adjusting the stat, and the stat operating normally.
Lux stats, aren't made to be high quality. |
#5 |
problem was resolved since the Honeywell was installed
#6 |
lux used to be a good dishsoap never was a good tstat
lux socalled because you had to rely on your luck that your system worked after it was installed ![]() happy holidays |
| Display Modes | |
| Trane XE80 not(?) hot enough | rossl56 | HVAC | 5 | 11-28-2008 03:34 AM |
| Trane XE 80 Problem | ShotgunW | HVAC | 14 | 12-30-2007 10:00 PM |
| Trane 80xl, 3 flashes error light - draft pressure problem, help? | Xsta | HVAC | 1 | 10-14-2007 09:20 PM |
| Trane XE80 Heating Question, Please help!!! | Stephen1977 | HVAC | 3 | 01-30-2007 07:34 PM |
