-   -   LUX digital stat Trane XE80 intermittant problem (http://www.diychatroom.com/f17/lux-digital-stat-trane-xe80-intermittant-problem-33506/)
rossl56 12-10-2008 06:19 AM
I just moved into this house and replaced the original Honeywell analog stat with the LUX programable stat. I used the 2 wire config, since there are only 2 wires from the furnace to the stat. It has been working fine for the last month except on 2 occassions that the furnace did not turn on. This does not happen all the time. When it does happen and I "manually" increase the thermostat the furnace turns on.
Example 1) This morning I noticed the temp was 65 the stat was set to 68, but the heat never came on. When I turned the stat to 69 the heat started. I have it programmed to go to 68 about an hour before I get up.
Example 2) The last time this happened I turned the stat down while the furnace was on. When the temp went below the stat setting the furnace did not turn on. Again I had to manually adjust the stat and everything worked fine, until today.
Should I suspect the stat or the furnace?
sammy37 12-10-2008 10:20 AM
Probably just a bad stat, Lux is not the best brand out there. Go over to lowes or H.D. and grab a good Honeywell stat. Make sure you shut the power off first so you dont fry your transformer or blow a fuse.l
rossl56 12-13-2008 12:26 PM
Got a Honeywell will return the LUX. Anyone else have an opinion?
My concern is that the furnace control board is getting "confused" when I interupt the heat on cycle by turning down the stat.
beenthere 12-13-2008 02:58 PM
The furnace doesn't know the difference between you adjusting the stat, and the stat operating normally.
Lux stats, aren't made to be high quality.
rossl56 12-25-2008 01:09 PM
problem was resolved since the Honeywell was installed
kennzz05 12-25-2008 06:32 PM
lux used to be a good dishsoap never was a good tstat
lux socalled because you had to rely on your luck that your system worked after it was installed :laughing:
happy holidays
rossl56 12-26-2008 05:53 AM
I had no lux with mine
