LSI Thermostat Stage Settings Trouble! - HVAC - DIY Chatroom Home Improvement Forum
Old 11-26-2008, 09:52 PM   #1
Unhappy
LSI thermostat stage settings trouble!
Hey ive got LSI electric furnace that has a lsi thermostat controlling it. Furnace is from 1974 my problem is the old thermostat has slider settings that slide around the dial inside. One slide is for stage one the other is for stage 2. the numbers on the dial range from .15 to 1.0. My question is what should stage one slider be set on and what should stage 2 slider be set on...please help me if possible
weydoggy is offline   Reply With Quote
Old 11-27-2008, 09:26 AM   #2
biggles's Avatar
those are your heat anticipation settings for the stages...go down on the gas valve with a flashlight and magnify glass you should see .## stage one .## stage two,slide the brass pins on or near the decimal values.......they don't control the temperatures like the actual temp settings ,but do effect it reacting when the room reaches your degree settings.
Totaline thermostat trouble shooting Goldwing93 HVAC 3 07-30-2009 10:35 PM
How to optimize thermostat settings (2 heating systems same home) rossl56 HVAC 1 11-26-2008 03:39 AM
thermostat wiring trouble telbroome@aol.com Electrical 3 11-01-2007 04:17 PM
2 stage heat thermostat problem W1 AND w2 wires whatdoIdonow HVAC 6 11-26-2006 12:04 AM
