Old 11-13-2005, 07:21 PM   #1
Lowest temperature
I own a rental property, currently vacant...I live in Minneapolis and winter is fast approaching...What is the lowest temp I can consistently set my thermostat at before I should start worrying about the water lines freezing? Thanks
matchupeabody is offline   Reply With Quote
Old 11-13-2005, 09:51 PM   #2
Contractor
Lowest temperature
Around here water freezes @ 32 deg. F. or 0 deg. C. anything above that should be fine.
My house in NC, I winterize by draining the water system and setting the thermostat at 50 deg. I have a bank of 3 100W lightbulbs in the crawlspace under the house controlled by a thermostat set at 40 deg. This has worked for 25 yrs.
The 3 bulbs are redundant, one would work but I'm not usually up there during the winter. I quit skiing years ago.
Teetorbilt is offline   Reply With Quote
Temperature Differance Over Coil rjordan392 HVAC 9 08-11-2007 06:34 PM
temperature rating for Romex Clutchcargo Electrical 7 07-24-2007 07:54 PM
Is there a way to circulate the outside temperature (air) into my home & take out hot 915855 Building & Construction 6 10-14-2006 04:19 PM
where is the lowest insuarance for construction company? iti General Discussion 6 12-19-2005 12:58 PM
