Low Voltage Problems!! - HVAC - DIY Chatroom Home Improvement Forum
Old 06-29-2011, 11:17 AM   #1
Low voltage problems!!
When I hook up the low voltage to my circuit board on my furnace it drops from 24 to 5. I've tryed 2 differant boards and have a new transformer that reads 24 when not hook to the board. If you can help it would be great. Thanks!
bkm2570 is offline   Reply With Quote
Old 06-29-2011, 05:14 PM   #2
An old Tradesmen
Rewards Points: 7,830
What VA is the new transformer.
Did you try leaving all other low voltage wires off, and seeing what voltage you read.
Old 06-29-2011, 05:37 PM   #3
biggles's Avatar
is the board tagged R and C backwards maybe with nothing connected you should read 24Vs where it connects to the board
Old 06-29-2011, 06:56 PM   #4
AKA HVACTECHFW
Rewards Points: 1,208
sounds like a bad stat or another load that is shorted in the low voltage circuit. I've seen contactors in ac units cause this.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
DC voltage from a PCB dave11 Electrical 3 07-20-2010 06:13 PM
low voltage wiring for niche lighting 8roty Electrical 4 01-16-2010 07:17 AM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 03:51 PM
Low voltage to vacuum l.schrankel@comcast.net Electrical 2 03-04-2007 09:38 AM
